Fiche technique Mustang 1971
Démarré par Thierry, 19 Septembre 2015 à 16:56:19
Carrosseries: Hardtop, Cabriolet, Sportsroof
You cannot view this attachment.You cannot view this attachment.You cannot view this attachment.
Construction: Monocoque
Production:
65D 2dr Hardtop: 65 696
63D 2dr SportsRoof: 23 956
76D Cabriolet: 6 121
65F 2dr Hardtop Grande: 17 406
63F 2dr SportsRoof, Mach 1: 36 499
Total: 149 678
Tarifs en 1971:
Hardtop: $2,911.00
SportsRoof: $2,973.00
Cabriolet: $3,227.00
Hardtop Grande: $3,117.00
SportsRoof Mach 1: $3,268.00
SportsRoof Boss 351: $4,124.00
Motorisations disponibles:
250cid 1V 6cyl 145cv
302cid 2V V-8 210cv
351cid 2V V-8 240cv
351cid 4V V-8 280cv (CJ)
351cid 4V V-8 285cv
351cid 4V V-8 330cv (Boss)
429cid 4V V-8 370cv (CJ)
429cid 4V V-8 375cv (CJ-R)
Couleurs disponibles et Codes
Raven Black A
Maroon Metallic B
Dark Ivy Green Metallic C
Grabber Yellow D
Medium Yellow Gold E
Grabber Lime I
Grabber Blue J
Wimbeldon White M
Pastel Blue N
Medium Green Metallic P
Light Pewter Metallic V
Grabber Green Metallic Z
Bright Red 3
Medium Brown Metallic 5
Silver Blue Metallic 6
Light Gold 8
Gold Metallic Special
Gold Glamour Special
Sellerie intérieur – Code:
Black vinyl 1A
Medium blue vinyl 1B
Vermillion vinyl 1E
Medium Ginger vinyl 1F
Medium Green vinyl 1R
White vinyl 1W
Black knitted vinyl 3A
White knitted vinyl 3W
Vermillion cloth & vinyl 2E
Medium Ginger cloth & vinyl 2F
Medium Blue cloth & vinyl 2B
Medium Green cloth & vinyl 2R
Black knitted vinyl 5A
White knitted vinyl 5W
Vermillion knitted vinyl 5E
Medium Blue knitted vinyl 5B
Medium Green knitted vinyl 5R
Medium Ginger knitted vinyl 5F
Black knitted vinyl CA
White knitted vinyl CW
Vermillion knitted vinyl CE
Medium Blue knitted vinyl CB
Medium Green knitted vinyl CR
Medium Ginger knitted vinyl CF
Black cloth & vinyl 4A
Medium Blue cloth & vinyl 4B
Vermillion cloth & vinyl 4E
Medium Ginger cloth & vinyl 4F
Medium Green cloth & vinyl 4R
Numéros d'identification VIN – Codes moteurs
250cid 1V 6cyl 145hp L
302cid 2V V-8 210hp F
351cid 2V V-8 240hp H
351cid 4V V-8 280hp (CJ) Q
351cid 4V V-8 285hp M
351cid 4V V-8 330hp (Boss) R
429cid 4V V-8 370hp (CJ) C
429cid 4V V-8 375hp (CJ-R) J
1 – Dernier numéro de l'année modele
F – Usine d'assemblage (F-Dearborn, T-Metuchen)
01 – Code carrosserie 01 pour Hardtop (02 SportsRoof, 03 cabriolet, 04 hardtop Grande, 05 SportsRoof Mach 1)
M – Code moteur
100001 – Numero d'unité consécutif
Exemple: 1F01M100001
Performances:
Vitesse maxi
108 mph (302cid)
0-60 mph
8.1 secondes (302cid)
0-100 mph
24.6 secondes (302cid)
Consommation:
16 miles par gallon (V8 210cv)
Spécifications:
Distance entre essieux: 109″
Hauteur: 50.1″
Largeur: 74.1″
Longueur: 189.51″
Poids: 3560 livres (351CJ)
Informations moteurs:
250 c.i. I-6 1V Carburateur simple corps
Taux de Compression
9.0:1
Puissance
145@4000
Couple
232@1600
302 c.i. V-8 2V Carburateur double corps
Taux de Compression
9:5
Puissance
210@4600
Couple
296@2600
351 c.i. V-8 2V Carburateur double corps
Taux de Compression
10.0:1
Puissance
240@4600
Couple
350 @2600
351(CJ) c.i. V-8 4V Carburateur quadruple corps
Taux de Compression
9.0:1
Puissance
280@5400
Couple
370@3400
351 c.i. V-8 4V Carburateur quadruple corps
Taux de Compression
10.70:1
Puissance
285@5400
Couple
370@3400
429 c.i. CJ-R 4V Carburateur quadruple corps
Taux de compression
11.3:1
Puissance
370@5400
Couple
450@3400
429 c.i. SCJ-R 4V Carburateur quadruple corps
Taux de compression
11.3:1
Puissance
375@5600
Couple
450@3400
Pour tout commentaire ou suggestion d'amélioration, merci de poster dans ce sujet:
https://www.mustangv8.com/fr/technique-mustangs-anciennes/fiches-techniques-mustang-premiere-generation/
Brochure:
[attach=1][attach=2][attach=3][attach=4][attach=5][attach=6][attach=7][attach=8][attach=9][attach=10]
