Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Contact
Login
Register
Forum
Ford Mustang forums
Your Mustangs
Topic:
New from Belgium
Pages:
1
2
Go Down
Author
Topic: New from Belgium (Read 10931 times)
exxodus
Jr. Member
Gender:
Notre passion? Une légende!
Mustang: 1969 Coupe
Daily driver: Exxodus (me)
New from Belgium
on:
June 01, 2009, 04:46:04 AM »
As i just register to this forum, let me my 69 coupe. I'm From belgium, and got a 1969 V8 302 Coupe Mustang. Lot’s of mods where applied to the car like, some goodies to the engine (will be replaced by a brand new 347 crate engine in september), T5 5 speed trans, a 0'' ford 3.55 (read end), 03 mach1 wheel (17”), line lock, cut outs, ... and more to come.
Let's go for some pictures.
More of My (and lot's of other) mustang pictures :
http://www.flickr.com/photos/exxodus/collections/72157594588295559/
Gender:
Re: New from Belgium
Reply #1 on:
June 01, 2009, 06:16:36 AM »
Put all of those pictures in the June photo contest. Your chances of winning will increase by more pictures. Take some of the engine compartment and the interior as well. Let's see lots of pictures of that beautiful beast.
exxodus
Jr. Member
Gender:
Mustang: 1969 Coupe
Reply #2 on:
June 01, 2009, 11:09:40 AM »
All started in 2002, i bough this Mustang 69 coupe in Belgium. It's a DSO 90 (export), in fact the car was build in Belgium and sold to a football tem mmanager here, in belgium. In the late 70ies, he sold it to a man that alreadu got the same mustang (same 302 coupe, same color, etc.).
As i discovred it:
It was in pretty nice condition, but need some work to get on the road for long distance trip. So i made some modification.
Starting with renewal of the engine compartment, upgrading to a Edelbrock performer intake, edelbrock 650cfm carburator, Headmann long header, new alternator, water pump, radiator, ragulator, ... etc.
From this
to this
(in progress pictures)
exxodus
Jr. Member
Gender:
Mustang: 1969 Coupe
Reply #3 on:
June 01, 2009, 12:20:37 PM »
Then 1st probleme .. no more fuel to the pump .. so i decide to change pump & fuel tank.
Old & new Pump (Holley "12-833")
Did i mention, i was on a trip when my fuel pump die? Trailler needed to get home !
exxodus
Jr. Member
Gender:
Mustang: 1969 Coupe
Reply #4 on:
June 01, 2009, 12:30:35 PM »
Then winter comes ... time for a T5 Swap ! ;-)
PS cylinder Boot & Bushing kit F1621 (116)
T5 shifter lever ENG670092
5 speed knob TRA678102
Centerforce disk 280490
Centerforce I pressure plate CF360030
Throw out bearing N1439
Flywheel Centerforce 700225
Pilot bushing N20
T5 World Class
T5 adapter for 4 speed bell housing
T5 transmission crossmember
T5 transmission mount
Drive shaft yoke 28 spline
Center force pressure plate, center force cluch disk, ans World Class T5.
Sorry no pix of the T5. It was from a Cobra.
exxodus
Jr. Member
Gender:
Mustang: 1969 Coupe
Reply #5 on:
June 01, 2009, 12:45:17 PM »
Some month later, time to front/rear suspension modifications.
NPD :
http://www.npdlink.com/
Eaton leaf springs special 1" lowering 5560-35 ( 58 ) rate 138 1
Le rate c'est le nombre de livres qu'il faut pour compresser les lames d'un pouce. Donc ici, 138 Livres.
Super grease prothane urethane 19579-1A (55) 1
Spring seat coil spring dichromated with urethane inserts 3388-1P pair (55) 1
Insulator coil spring upper 5415-2P (55) 1
PST :
http://www.p-s-t.com/
Performance Super Front End Kit 1
. 2 upper control arm assemblies
. 2 lower control arm assemblies
. 2 outer tie rod ends
. 2 inner tie rod ends
. 2 tie rod adjusting sleeves
. 1 idler arm or idler arm bushing
. 2 polygraphite stabilizer links
. 2 polygraphite sway bar bushings
. 2 polygraphite strut rod bushings
. Control arm bumpers
Catalogue PST
MU :
http://www.mustangsunlimited.com/
Contour Coils by Traction Master C307 - pair (132) 1
Rear spring U bolts and nuts 67730 (133) 4
Front sway bar kit 537 1" (133) with mounting brackets, urethane bushings and end link 1
Stam Bar rear stabilizer bar kit 3/4" 1SB (133) 1
Front bolt for rear spring C5ZZ5600AR 2
Shackle kit urethane CLB350 - pair (110) 1
Front spoiler plastic PL19079 1
CJ Ponyparts :
http://www.cjponyparts.com/
Gas-a-just KYB shocks, front and rear KYBK4 (30) 1
MAC's :
http://www.macsautoparts.com/
Emergency brake equalizer bracket C6OZ-2A602-A (54)
exxodus
Jr. Member
Gender:
Mustang: 1969 Coupe
Reply #6 on:
June 01, 2009, 12:50:01 PM »
Time for Sequential tail light & Grant wheel.
exxodus
Jr. Member
Gender:
Mustang: 1969 Coupe
Reply #7 on:
June 01, 2009, 12:54:29 PM »
Then my first error : 2003 mach1 wheels !!
exxodus
Jr. Member
Gender:
Mustang: 1969 Coupe
Reply #8 on:
June 01, 2009, 01:12:16 PM »
2005 !
Time for a 9'' rear end & rear disk breakes !
Rear End > 9" > Detroit Soft Locker > gears 3.55:1 - 31 splines.
Brakes > Rod & Customs - kit RC-131.
Cal tracks > CAL-TRACS (
http://calvertracing.com/caltracs.php
Line lock > Summit
exxodus
Jr. Member
Gender:
Mustang: 1969 Coupe
Reply #9 on:
June 01, 2009, 01:14:52 PM »
exxodus
Jr. Member
Gender:
Mustang: 1969 Coupe
Reply #10 on:
June 01, 2009, 01:48:06 PM »
2006 // time for a new paint !
Welding
Painting
We all fade to grey !!
Final product !
(Did you notice the Logo ?)
exxodus
Jr. Member
Gender:
Mustang: 1969 Coupe
Reply #11 on:
June 01, 2009, 03:36:09 PM »
More news tomorrow...
Gender:
Reply #12 on:
June 01, 2009, 03:52:35 PM »
She sure is a beautiful Mustang. You do really good work.
stang98
Guest
Reply #13 on:
June 02, 2009, 04:31:46 PM »
Welcome and you made me not want to put my car in mustang of the month.
Konrad
Gender:
Mustang: 2007 GT 5 speed
Daily driver: that is my daily driver
Reply #14 on:
June 03, 2009, 11:21:44 AM »
lol me too.
exxodus
Jr. Member
Gender:
Mustang: 1969 Coupe
Reply #15 on:
June 03, 2009, 02:09:39 PM »
C'mon guys... how could you be afraid of a litle belgian boy
Gender:
Reply #16 on:
June 03, 2009, 03:39:56 PM »
This is a fun thing guys. There is no money or prizes involved. It's a chance to really show off our cars on the net. So, go ahead and post a ton of pictures of your ride. I guarantee nobody is going to feel bad about posting their ride's pictures. I have the ban stick handy for anyone who makes fun of another Mustanger's ride.
I'll tell you what. I have a plane Jane 1965 coupe, and I will post a bunch of pics of it. It will show the work I have done, and the work yet to be completed if you will do the same. Deal?
exxodus
Jr. Member
Gender:
Mustang: 1969 Coupe
Reply #17 on:
June 03, 2009, 04:33:09 PM »
So ... Exxo'stang rebuild S2E1
Time to take care of the Interior and somes details.
Cleaned & fresh paint
Floor has been completely cleaned
The soundproofing was placed everywhere possible (floor, quater panels, firewall, etc.)
Plastic parts painted or replaced by new ones.
Standard instrument panel replaced by deluxe one (tks ebay)
Racing mirrors.
Safety loop
Line lock.
New carpet, seats, etc..
Hey ... Someone stole my car !!
Gender:
Reply #18 on:
June 03, 2009, 05:34:18 PM »
Your passenger side bucket seat cover corner doesn't fit. Looks like shit.
exxodus
Jr. Member
Gender:
Mustang: 1969 Coupe
Reply #19 on:
June 04, 2009, 12:58:20 AM »
Thanks to the " MU Made in China Reproduction Seat Cover " ... I literally fought with that thing for hours and the result is the best that I could get.
Pages:
1
2
Go Up
Forum
Ford Mustang forums
Your Mustangs
Topic:
New from Belgium
Subject / Started by
Replies
Last post
classic parts retalier in Belgium
Started by
Mat
May 05, 2011, 08:04:47 PM
by
Navigation
Used Cars for sale
Ford Mustang classifieds
Powered by
EzPortal
