Author Topic: swap a v8 5.4 F150 motor to v6 mustang 01???  (Read 14985 times)
hitme4life
  • Mustang: 2001 V6
« on: July 27, 2009, 01:47:36 AM »
Can it be done??? what i'll need to do??? it be better the same year as the car?
69fast
  • Mustang: 69 fastback mach 1
Re: swap a v8 5.4 F150 motor to v6 mustang 01???
« Reply #1 on: August 22, 2009, 11:33:49 PM »
first of all you bought a v6 big mistake, second you will probaly have to replace all the drivetrain the torque of the 5.4 will f*** it all up then you will have to replace the frame because the frame of a v6 will bend like a penis running into a brick wall so this is a very bad idea and the 5.4 is a huge beast motor so it wouldnt fit.
« Reply #2 on: August 25, 2009, 10:04:14 AM »
im not sure if the v6 and 4.6 share a common K member  if so you can use it then you will need motor trans and a rear end
are you wanting to make a 2000 cobra r clone?? the engine does fit 69fast it was installed in 32v configuration in the 2000
Blown2v
  • Mustang: 2003 GT
  • Daily driver: 2003 GT
« Reply #3 on: October 29, 2009, 11:22:20 PM »
yeah you can do it, its possible I dont think you will actually have to replace all the frame really. Just you will need most likely a new harness, computer, and a decent amount of other things. But thats just too much work should of just bought a v8 2, 3, or a 4v.
« Reply #4 on: November 01, 2009, 05:04:08 PM »
If it were a classic going to a V8 from a straight 6 it would take a lot of money and time to do it, but it would possibly be worth it in the end.  However, a V6 going to a V8 in a modern Mustang is pointless.  The car is basically depreciated and will never be worth much anyway.  Just sell the V6 and get yourself a V8 at a fraction of the cost it would take to convert.
Blown2v
  • Mustang: 2003 GT
« Reply #5 on: November 10, 2009, 12:27:52 AM »
+1 you would save some money
