Author Topic: 88 4cyl engine swap  (Read 46383 times)
Re: 88 4cyl engine swap
« Reply #20 on: March 30, 2008, 04:24:02 PM »
If you don't upgrade the suspension components you can get by, but will be putting extra weight on those 4 cylinder components.  If you are going to do it.....do it right.  Southern engineering is not allowed.
xnutt
« Reply #21 on: June 29, 2008, 08:58:45 PM »
LMAO southern engineering...... thanks i needed a good laugh.
the 93 cobra r's used 4 banger springs but nothing else (had something to do with road racing and handleing).
i'm working on a rough draft of the write up now.
o a side note a 6 banger's k member is the same as a 4 or 8 cycl. the only one different is the 79-82 I6. the 79-82 I6 cars would require the k member to be swaped in order to drop a v8 in.
« Reply #22 on: March 25, 2009, 05:02:19 PM »
the only difference between a 4 cylinder suspension in a fox is the brakes, and the front springs. the springs are used for a cheap 1 inch drop. the brakes used on the 4 cylinder should be upgraded to something a little larger. either stock 5.0liter stuff or go for 5 lug lincoln mark 7 stuff
« Reply #23 on: March 26, 2009, 04:04:36 PM »
You sound like a shade tree mechanic Stephen.   The suspension on that 4 banger car is simply too weak for a V8, and the brakes will not stop that car safely because of the added weight. That weak transmission and rear end will leave that Mustang stranded on a road somewhere.  If you are going to do it, then do it right the first time.
« Reply #24 on: March 26, 2009, 04:18:19 PM »
the rear end (7.5) was used until the 1985 model year in v8 cars. 86+ got the stronger 8.8
the 4cylinder t5 will even last behind a stock v8,what kills the trannys is nto having a good shifter and slicks
the brakes iirc up until 1987 all 4 cylinder cars used the same brakes
so really the only thing that must be upgraded is the spring if you dont want the car lowered 1 inch :P
« Reply #25 on: March 26, 2009, 04:32:16 PM »
I think we are arguing about nothing, Steve.   He has an '88.  Ford dropped the 7.5 in the 1986 models, not 85.  But, at any rate, he has a decent 8.8 rearend in there, so just the tranny needs to be replaced along with the brakes.  That is not the same strong T5 you are thinking of.  http://www.moderndriveline.com/Technical_Bits/transmission_spec.htm
« Reply #26 on: March 26, 2009, 04:36:52 PM »
the t5 will last a lot of 5.0 guys run them as cheap replacements true the torque capacity isnt as high. any t5 will grenade.
if he has a 4cylinder car(even a 86-93) it still has a 7.5 rear axle, but it will definitely hold up to a stock v8
« Reply #27 on: March 26, 2009, 05:17:45 PM »
I have said it many times that those 80's and early 90's engines were weak assed crap, and I guess if Ford continued to use the 7.5 that just proves it.  The Bronco gave up the 7.5 in 86.
« Reply #28 on: March 27, 2009, 12:52:28 AM »
the v8 cars gave up the 7.5 that previous 5.0s used
and 5.0s werent very weak :P they were 225hp and 300ftlbs of torque same as an "A" code 289 and they were faster
« Reply #29 on: March 27, 2009, 07:59:16 PM »
The more I keep reading about the 7.5 and the 8.8 the more I realize that both you and I are worng, unless this is a completely different 7.5 than Ford used in the mid 60's 6 bangers.    Check this out.
Question #3 - Does my V6 Mustang have a "Trak-Lok" rear end?
No. The 1994-2007 V6 Coupe is delivered with a 7.5" open (non-lock up) differential. The V8 Mustang GTs have an 8.8" Trak-Lok rear in the stock configuration.
Question #4 - How much power will my V6 Mustang Trak-Lok rear end handle?
According to most sources, the 7.5" Trak-Lok will safely handle up to 450Hp. The 8.8" Trak-Lok will handle even more.
« Reply #30 on: March 27, 2009, 09:04:30 PM »
nope is a different rear axle assembly. heres a pic of an 8.8 the 7.5 looks nearly identical
« Reply #31 on: March 28, 2009, 01:27:22 AM »
Ok, then that 'splains it.  I kept thinking we were talking about the old 7.5.
« Reply #32 on: March 28, 2009, 11:04:15 PM »
your mach 1 uses an 8.8 ;) crawl up under it and you can get a first hand look.
the 7.5 and 8.8 will even share brakes and axels
« Reply #33 on: March 29, 2009, 02:52:06 AM »
Yeah, I know my Mach has the 8.8, but again, I thought the 7.5 was the old 7.5 used in the 60's 6 bangers.  I guess I need to do some more reading about the latest, huh?   ;D
