August 20, 2008, 05:30:40 AM *
Author Topic: rear shock length  (Read 2341 times)
Oz66FB
Jr. Member
hi guys,
anyone able to help?
thanks
Oz
Sr. Member
Oz66FB
Jr. Member
thanks again for your help
Sr. Member
Ben,
Oz66FB
Jr. Member
thanks Jim
Which Cab????
Oz66FB
Jr. Member
too true Glen
Sr. Member
Ben,
Oz66FB
Jr. Member
Sr. Member
Oz66FB
Jr. Member
Oz66FB
Jr. Member
hope this works
Oz66FB
Jr. Member
« Reply #13 on: May 19, 2008, 06:14:38 PM »
http://www.autopics.com.au/cache/item-3740public.html?cache=no
Oz66FB
Jr. Member
