1965 Mustang fastback St Martins NB
1974 Ford Mustang II
girl mustang mach2
oldtimertreffen f bach2008 010
2007 Ford Mustang GT 520
Author Topic: 1965 mustang rf wheel brake problem.  (Read 1155 times)
bill6567
  • Mustang: 1965 fastback&1967 fastb
  • Daily driver: 65 & 67
« on: August 22, 2008, 04:46:39 PM »
The problem is that when I hit the brakes it pulls to the right. I have taken it apart and examined every thing and have adjusted it several times and its ok for a little bit and then goes back to pulling to the right again. I think there's a defective part, but don't which one. Anybody have an answer for this. Thanks
Re: 1965 mustang rf wheel brake problem.
« Reply #1 on: August 22, 2008, 05:20:34 PM »
Three things come to mind.  The first is maybe you have a leaky wheel cylinder getting fluid on the shoe.  Two- the automatic adjuster is not on there right and adjusts too tight too soon.  If this is the case, then you would have a difficult time getting the drum off.  And third - the drum is grooved.  If that is the case, then get it turned or get a new drum.  I will take a picture of mine with the drum off tomorrow so  you can compare.
bill6567
« Reply #2 on: August 22, 2008, 05:33:43 PM »
I did have trouble getting the drum off and had to take a screwdriver and adjuster spoon to undue it to take the drum off. Did not see any fluid.
« Reply #3 on: August 22, 2008, 06:54:59 PM »
Ok, make sure that automatic adjuster is on right.  Look at the driver's side to compare.  The little fat "L" shaped piece of metal that hits the grooves on the adjuster must be just right.  When you have it right, you should be able to turn the drum fairly easily and just hear a "hiss" of rubbing.  If you have a difficult time turning the drum, then it is too tight.  Both sides must be exactly the same.  Let us know.......
bill6567
« Reply #4 on: September 06, 2008, 07:21:34 PM »
My friend and I got at the brakes today and found the Right Front was fine, but the Left Front was not. Live and learn. Thanks for your help.
« Reply #5 on: September 19, 2008, 03:00:27 PM »
What was wrong with the left front?
bill6567
« Reply #6 on: September 19, 2008, 03:24:14 PM »
Adjuster was stuck.
« Reply #7 on: September 19, 2008, 04:24:44 PM »
That'll make it happen every time.  Glad you found the problem.  I usually have about 14 beers after getting an anoying problem like this solved.   ;D ;D
bill6567
« Reply #8 on: September 19, 2008, 06:35:08 PM »
By any chance do you know where I can find a pair of polyurethane washers? Not insulators for shocks or steering stabilizers. I saw red ones being used on exhaust brackets, and I called Midas because thats where i thought saw them, but they said they did not have them. Thanks
wheel size for a 289 '66
Suspension, brakes and wheels
collongues 5 10532 Last post April 28, 2008, 02:12:40 PM
Help w/ brake-light problem ('69 Mach I)
Electrical discussions
kylek 1 8087 Last post June 12, 2005, 11:38:52 PM
by Jerry Baker
70 mustang-disc brake update
HRTRacers 1 4374 Last post March 15, 2006, 09:40:54 PM
by racedraper
1965 Mustang Comercial
Mustang commercials
Thierry 0 772 Last post November 27, 2007, 01:14:15 PM
by Thierry
1967 mustang play in the steering wheel
poikusr 3 1217 Last post February 12, 2008, 07:25:19 PM
99 ford mustang fuel pump, filter problem
4.6 Mustang technical forum
airwaves 1 565 Last post August 07, 2008, 12:13:24 AM
by rmodel65
1965 mustang V8 2v 289
bhorrocks 4 728 Last post September 05, 2008, 08:00:47 PM
by bhorrocks
classic mustang cut off switch problem?
anrace 6 523 Last post September 26, 2008, 06:15:43 PM
by 66GTKFB
Ford Mustang brake problems?
anrace 2 313 Last post September 20, 2008, 01:13:50 AM
by airwaves
89 Ford Mustang Transmission Shifting Problem?
Drivetrain
anrace 2 319 Last post September 20, 2008, 03:34:29 AM
