im not sure about a cobra/lightning engine/trans even fitting into a 98 without modifying the motor mounts....but whatever engine you get, make sure you get the main wiring harness, ECU, PCM, Steering column, Key, & Gauge Cluster...you will need all this stuff because of the PATS.
