Author Topic: Trying to motor swap a 98 gt need help  (Read 4815 times)
nasty98
  • Mustang: 98 gt verti
« on: June 07, 2009, 11:30:52 AM »
I am trying to swap the 4.6l sohc cause it needs head work and I want more power, so I want advice of what I would have to do in order to swap a later model cobra motor in it or maybe even the 5.4l.  I don't know what I will need to make it work and I would like some help.
Re: Trying to motor swap a 98 gt need help
« Reply #1 on: June 07, 2009, 03:34:26 PM »
For the Cobra swap,  it will run off your existing wiring harness (need to lengthen the coolant temp harness and coil pack). It'll run off your stock ECU, but i do suggest getting an SCT tune.
It's an easy swap, provided you get all the accessories with it.
Welcome to the site Nasty.
nasty98
« Reply #2 on: June 07, 2009, 04:59:37 PM »
what is the allowed year I can go up to?
03SoniCobra
  • Mustang: 2000 mustang
« Reply #3 on: June 08, 2009, 02:36:46 PM »
im not sure about a cobra/lightning engine/trans even fitting into a 98 without modifying the motor mounts....but whatever engine you get, make sure you get the main wiring harness, ECU, PCM, Steering column, Key, & Gauge Cluster...you will need all this stuff because of the PATS.
nasty98
« Reply #4 on: June 08, 2009, 04:40:13 PM »
but I would imagine that it would bolt right up cause its a 4.6 as well, but I would have to make sure everything is copastetic if not then I'm without a whip
