Author Topic: Rear End Still Leaking  (Read 3333 times)
Re: Rear End Still Leaking
« Reply #20 on: March 14, 2010, 05:32:24 PM »
You probably should use the old throw away towel method of soaking out the old 90W.
Mickey Mouse was (and is) the figure of speach used to describe something that is done so bizzare as to rate a new description but to combine the different situations into a common "group", the term "Mickey Mouse" is used.
Areese3990
  • Mustang: 2000 Mustang Gt
« Reply #21 on: March 15, 2010, 11:06:41 AM »
yeah i think i am going to try to soak up the majority of it with a few old rags and some shop towels
« Reply #22 on: March 15, 2010, 01:56:04 PM »
You can mix a little bit of dino gear oil with synthetic without a problem.  Just get out as much of the dino as you can, then add the synthetic.
Areese3990
« Reply #23 on: March 15, 2010, 06:40:07 PM »
by dyno oil i assume you mean the non synthetic correct? and should i still stick with the same wieght.
« Reply #24 on: March 16, 2010, 02:26:15 AM »
Dino means non-synthetic. (dinosaur)  Get out as much of the dino as you can, then add the synthetic.
Areese3990
« Reply #25 on: March 16, 2010, 10:15:20 AM »
will do. i just got a call from the dealership and my cover is in so ill let you guys know how is goes and how i go about doing it!
Areese3990
« Reply #26 on: March 16, 2010, 10:37:15 PM »
complete!!!! :D
i ended up getting most of the fluid out with some of those blue shop towels which are great by the way and then i leveled out the car by putting some jack stands up front which to be honest looked a little sketchy at first but it was fine. ended up taking the traction bar off and all four bolts were cross threaded so they were fun to take off. but other than that ever thing went rather smooth thanks for all the input soaring, bigbob and 66gtkfb.
« Reply #27 on: March 17, 2010, 01:06:57 AM »
Glad you got her fixed and back on the road.
Last post February 10, 2008, 07:27:43 PM
Last post December 08, 2008, 09:01:51 PM
Last post January 25, 2009, 12:20:09 AM
by mustangwannabe302
Last post December 05, 2009, 10:14:28 AM
by relic1864
Last post February 17, 2010, 06:48:47 PM
by 66GTKFB
