Author Topic: Question about VIN  (Read 3011 times)
Coach
  • Mustang: 1968 Convertible
Question about VIN
« on: July 04, 2008, 02:36:23 AM »
I am a new Classic Mustang owner, and have a question about a "problem" I have with the VIN information on my 1968 Convertible.
On the door tag the VIN# starts "8T01". According to VIN codes this tells me that the car was produced in'68 in New Jersey and with a body code that is a coupe. Under the VIN#, in the data code, the body is listed as 76B, which is the convertible body with the luxary interior. Why is the body code for a coupe and the body type for a convertible? Any help would be greatly appreciated.
keiken01
    • My 1968 Mustang
  • Mustang: 1968 Coupe
Re: Question about VIN
« Reply #1 on: July 04, 2008, 09:38:34 AM »
Sounds like someone swapped out the door from a coupe.
Coach
« Reply #2 on: July 04, 2008, 09:55:12 AM »
But the descrepency(sp?) is on the same medal stamped tag.
« Reply #3 on: July 04, 2008, 11:13:48 AM »
Discrepancies happen with VINs sometimes. Keep in mind that in the era when your car was built, a lot of auto workers were, uh - 'a bit under the weather' (or something similar). You should verify all the VINs on your car; the one on the door, the one riveted to the body at the left windshield and the title. A further check can be made with Kevin Marti at http://www.martiauto.com/ Kevin bought the Ford assembly line database for 1967 thru 1973 Fords and can give you a lot of information about your car - for a price of course, around $30.00.
Coach
« Reply #4 on: July 04, 2008, 03:14:42 PM »
Thanks.
« Reply #5 on: July 04, 2008, 11:12:31 PM »
Yeah, the door tag is virtually useless because that door could have been replaced a dozen times.   The other codes that are located on your dash and under your hood will most likely be more accurate.
Last post March 07, 2006, 11:03:06 AM
by Jerry Baker
Last post June 30, 2008, 01:21:14 AM
by rmodel65
Last post July 22, 2008, 07:23:09 PM
Last post July 28, 2008, 05:21:35 AM
