Author Topic: PLEASE HELP!!!!!  (Read 1302 times)
66colton
  • Mustang: 1966 mustang
  • Daily driver: will be
PLEASE HELP!!!!!
« on: May 18, 2010, 12:20:12 AM »
i have a 66 mustang with a 86 302 carborated 5.0 i have a t5 and i think  :-[ a 8.8 rearend. how much horses and torq should i be throwin out?  :-\
Re: PLEASE HELP!!!!!
« Reply #1 on: May 18, 2010, 10:11:13 AM »
Assuming a stock 5.0 engine set up, horsepower will be in the range of 190-225 horsepower at the flywheel.
Any changes, modifications or tuning issues could easily result in numbers 25% off in either direction
66colton
« Reply #2 on: May 18, 2010, 12:27:02 PM »
thanks for the quick reply :) i figured it would be a lot more.... how much does a 289 put out??? and we are talking 4 barrel right???
« Reply #3 on: May 18, 2010, 01:13:58 PM »
Yes we are talking a 4 barrel
289's in various performance levels were available from Ford with horsepower ratings from as low as 195 up to the Carrol Shelby tuned 289 Hi po's in the Shelby cars that were rated at 306 horsepower IIRC.  A 289 HiPo was rated at 271 horsepower.
There is nothing significantly different between a 289 and a 302/5.0 other than balance issues that must be observed.  A 5.0 with good heads and the right cam can easily duplicate the 289 Hi po numbers across the board.  I would venture to guess that if built with identical components the 302/5.0 would make virtually the same power as the 289 with a tad more torque and maximum power coming just a few RPM lower than the shorter stroked 289, but for all intensive performance purposes the engines are identical.
structurally, the 302 blocks have longer bores and support the pistons a bit more and MAY have a little longer longevity under hard usage.  Again, in reality, you would be hard pressed to actually see any benefit of one over the other.
210 horsepower doesn't seem like a lot by today's modern standards, but it is more than enough to overwhelm your 1966 chassis.
You can get more with a more aggressive cam, better heads, headers, improved ignition etc, but you will quickly discover that your car can't use the horsepower without suspension modifications.
Enjoy your car and don't worry about "numbers"
66colton
« Reply #4 on: May 19, 2010, 01:39:04 AM »
man im new to this forum and i love it already im only 18 so when the hp numbers come to play i think big is better.... my dad has a 65 mustang with a 289 4 speed all factory code A and it gets it pretty damn good.... just out of curiosity could i beat him with what i have.... as far as i know the only thing done to the motor is headers.... sorry bout all the questions but im very curious.  8)  ;D thanks for the prompt replies also  ;D
« Reply #5 on: May 19, 2010, 04:27:23 AM »
It will depend on who is the best driver.  You both have basically the same motor.  It will also depend somewhat on what gears you both have in the rear.
