Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Contact
Login
Register
Forum
Ford Mustang forums
Mustang Discussions
Topic:
Overhaul kit and hints
Pages:
1
Go Down
Author
Topic: Overhaul kit and hints (Read 4485 times)
Russ
The one to watch for
Gender:
I am part of the 2 percenters in America
Mustang: 1973 FORD MACH ONE
on:
May 18, 2008, 01:31:20 PM »
I am looking for the complete overhaul kit for my 351C 2V. I would also like some hints on what you would like to do to make my 177 HP motor run faster without changing the look of the motor. Supercharger or blower is out of the question but cam and roller opinion always worth hearing about. STANG OUT
Photo contest winner
Daily driver: 1969 VW Baja
Re: Overhaul kit and hints
Reply #1 on:
May 18, 2008, 07:00:53 PM »
An air cleaner would hide a four barrel carburetor, but a set of higher compression pistons and a cam are also a good choice.
Russ
Gender:
Reply #2 on:
May 18, 2008, 09:18:43 PM »
well I am trying ot find the pleumem for the ram air, and that would be hot, and I got my 3:55 gears today . STANG OUT
Keep the info comming thank
Gender:
the mustang man
Mustang: 65 fastback modded
Daily driver: 1991 gt vert
Reply #3 on:
May 18, 2008, 10:32:09 PM »
i bought my master rebuild kit from paw(they have the 2 page low color ad in hot rod etc.) i bought the master racing instead of the plain rebuild it had pop trw forged pistons balanced rotating assembly etc i think it was around 1400$ balanced etc
a good 4v intake and some headers and a nice cam a 351 c will be a 400hp motor
Russ
Gender:
Reply #4 on:
May 19, 2008, 04:49:20 PM »
Yeah but I cannot use a 4v since I have a two valve, Right? I don't know for sure but think I have to match it. I would like to get a guide to what all came in that rebuild kit. I would like to get something like that thanks
Gender:
Reply #5 on:
May 19, 2008, 05:03:30 PM »
Nah, you can add a 4v intake manifold and a 4 barrel carb to 351 2v heads, but you aren't gaining much. Check out putting some aftermarket aluminum heads such as AFR's then add the 4v intake such as a Weiand Stealth and a 750 cfm Holley with some decent long tube headers and an X pipe with your twin 2 1/2" pipes and flowmaster 40 series, then you will have a seat grabbing setup with those 3.55 gears, but you will get a bigger punch with 3.73's up to the 4.10's. Now, that all is based on the fact that you also rebuilt the bottom end of the engine with correct pistons, rods and crank. However, this will drastically change the look of your original engine. If you want to keep it original looking when you pop the hood, then follow Jim and Stephen's advice. Power costs a lot of money. And, no.....hotrodding is not out of vogue...just enough money to geter dun..... I guess what I am saying, is that there are a lot of companies who make basic rebuild kits for all engines, but if you want it to be more than the basic 351 engine at say 277 hp that you already have, you need to be inventive and get outside the box to think about your engine rebuild.
Russ
Gender:
Reply #6 on:
May 19, 2008, 05:19:39 PM »
Yeah, I really trying to get the HP without the look. I think I would put an alummium intake and headers but that would be it. I couldn't put those heads on there, don't get me wrong I would love to dump alot of money into the motor but then I would start to get away and then the car would end up so far from factory then I would waste a car that I am a second owner and has had nothing done to it expect oil change. I am still checking into everything,now if I put a good intake on the 2v and card could I run it as well as the 4V.thanks Soaring
Gender:
Reply #7 on:
May 19, 2008, 05:26:55 PM »
Not a problem buddy...I would also keep it original. And right now, you don't have to do anything but change the oil and filter, check the timing, change the plugs and change the points to do a tune-up. I would spend my energy on the body of that Mach for now. You can worry about how it runs once you get it out of the garage with a new coat of paint.
Russ
Gender:
Reply #8 on:
May 19, 2008, 05:35:49 PM »
I am going to get rids of those points I have only driven her about 10 times and she runs good tell you get her to about 65 and then starts to cough out on me. I am going to have to take the motor out to get these fender aprons on and I would like since it makes sense to clean the motor up then but who knows. I am also trying to find a way to keep that OK stamp on there. Keep the ideas comming.
Gender:
Reply #9 on:
May 19, 2008, 06:10:20 PM »
Like I said, focus your energy on the body and interior for now since that is what you started with. Most guys go for the mechanics first when restoring, but since you have already obviously commited to the body, then stick with that plan. Then, your second plan would be the integrity of the frame and frame related body panels such as the floor pans. Then, the braking system needs attention. Either upgrade to disks on all fours or keep it as is. The next to last thing you need to spend money on is the engine and running gear if it is already running. And, the very last thing to be concerned about is the stereo system. The 70$ pertronix electronix system is all you need on that stock 351. It takes about a nano second to change from points to Pertronix.
Russ
Gender:
Reply #10 on:
May 19, 2008, 06:35:20 PM »
yeah I know when I get home I am going to jump the gun and have to have my better half and my Dad slow me down. Anyone that knows should be counting this trip home number 4 and this one is long overdue. But I am going to goo small. I will have to pull the engine for the fender aprons but will only clean the motor up might change the needed seals but that is all,FOR NOW>> That body is going to be the killer and I will be taken this computer with me and eveynight i will be inside loading it up on what I did. I might even need your guys help if you think I am swaying away and help bring me in before I go to far to quick. Stang Out
Gender:
Reply #11 on:
May 19, 2008, 08:06:04 PM »
We'll be here. Just take care of yourself.
Pages:
1
Go Up
Forum
Ford Mustang forums
Mustang Discussions
Topic:
Navigation
Used Cars for sale
Ford Mustang classifieds
Powered by
EzPortal
