Author Topic: New to Forum-need help  (Read 2540 times)
William Nickles
« on: May 24, 2010, 04:06:25 AM »
Bought a 63 Ranchero with what was reported as a 70-72 Mustang 302 engine transplanted.  How can I verify that this engine is indeed a mustang engine.  Where are the numbers stamped on the engine block and is there a chart that would tell me the specs/ID?  What about the tranny #'s.  The previous owner said the drive train came from a donor mustang.  Would like to know year/specs.
Thanks in advance-Bill
Re: New to Forum-need help
« Reply #1 on: May 24, 2010, 10:11:15 AM »
Welcome -
The transplanted engine would be difficult to verify as coming from a Mustang as a partial VIN was stamped on the block and may not incluced model type, plant or year. The range of years you have further complicates your quest. The VIN should be on the left rear block under the head (not sure, I don't have any cars or engines from that era). Federal law required the stamping but in typical fashion, federal law and the real world were (and are) far apart. The same applies to the transmission. You might want to do some reading in the FAQ section located in the Classic Mustang Technical Forum.
« Reply #2 on: May 24, 2010, 02:01:53 PM »
Here is an engine parts decoder.   If the 3rd digit is a "Z" then it is a Mustang engine.
http://mustangtek.com/FordDecode.html
« Reply #3 on: May 24, 2010, 06:01:49 PM »
If you find a "Z" as Glen states in the third position (digit) you will have either a 69 or 70 Boss 302 casting or will make Ford history as no production 302 blocks were made by Ford for Mustangs until 1975.
66colton
  • Mustang: 1966 mustang
  • Daily driver: will be
« Reply #4 on: May 25, 2010, 01:28:14 AM »
just enter the vin and go to the bottom and select the year on this handy dandy website and it will tell you what the car should have according to the vin
http://iml.jou.ufl.edu/projects/students/blommel/
« Reply #5 on: May 25, 2010, 10:22:22 AM »
The problem is that Ford got sloppy in its stamping of VINs on the block. Due to a hole in the federal law, a partial VIN may be present. With all the 70-72 types on the forum, how about you guys posting a picture of a VIN and its location on the block.
« Reply #6 on: May 27, 2010, 03:50:27 PM »
agree with Jim.  You 71-73 guys need to post your engine vins.  It will go into the FAQ if you do.
