Author Topic: motor mounts  (Read 1961 times)
harleyalien
  • Mustang: 1991
motor mounts
« on: August 01, 2009, 11:47:11 AM »
1991 GT 5.0, The old posting didn't ask what I needed to know, I need to know if the motor mount bolt spacing on the block is the same on a 1973 302 as it is on a 87/91 5.0. Will the 91 mounts fit on the 73 block??????? :'(
teju23451
Re: motor mounts
« Reply #1 on: August 07, 2009, 03:02:05 AM »
The fifth-generation Mustang is manufactured at the AutoAlliance International plant in Flat Rock, Michigan. The base model is powered by a 210 hp (157 kW) cast-iron block 4.0 L SOHC V6, which replaces the 3.8 L pushrod V6 used previously. The Mustang GT features an aluminum block 4.6 L SOHC 3-valve Modular V8 with variable camshaft timing (VCT) that produces 300 hp (224 kW). The 2005 Mustang GT has an approximate weight to power ratio of 11.5 lb/bhp. The base Mustang comes with a standard Tremec T-5 5-speed manual transmission while Ford's own 5R55S 5-speed automatic, a Mustang first, is optional. Though the Mustang GT features the same automatic transmission as the V6 model, the Tremec T-5 manual is substituted with the heavier duty Tremec TR-3650 5-speed manual transmission to better handle the GT's extra power
Obesity in Teenagers
medical transcription service
