Author Topic: Low fuel relay location  (Read 5307 times)
kansascdr
  • Mustang: 68 coupe
  • Daily driver: 1968
« on: April 10, 2011, 10:08:57 PM »
can anyone tell me where the low fuel relay is located on a 68 mustang?
Rat Fink
  • Mustang: 2011 mustang GT
  • Daily driver: 2011 mustang
Re: Low fuel relay location
« Reply #1 on: April 11, 2011, 05:46:46 AM »
It's on the dash, It's called a gas gage.
thundertc64
  • Mustang: 73 Mach 1 H code
« Reply #2 on: April 15, 2011, 05:14:56 PM »
The low fuel indicator failure is almost always due to a failed thermister. The thermister is located on the fuel sending unit in the fuel tank.
Rat Fink
« Reply #3 on: April 15, 2011, 06:31:23 PM »
Never heard of a thermistor until today.
thundertc64
« Reply #4 on: April 15, 2011, 07:13:39 PM »
Me either, I had to look it up
Mikey
  • Mustang: 1969 Mach 1
  • Daily driver: Rotisserie Restoration
« Reply #5 on: December 28, 2011, 08:11:21 PM »
are you referring the the low fuel optional convience light group???
kansascdr
  • Mustang: 68 coupe
« Reply #6 on: December 28, 2011, 09:42:56 PM »
Yes, the one on the optional console. My guage always reads about 3/4 full even with fuel running out of the spout. I cannot seem to find a new sending unit with the thermistor.  Anyone know where I can get one?
Mikey
« Reply #7 on: December 29, 2011, 07:46:26 PM »
Well the low fuel circuit comprises two main parts, the special fuel tank sending unit, and the relay located under the dash.  If you follow the special wiring harness (the one that has the four lights), you'll find a small match box size metal solenoid that the harness plugs into...Usually located on a bracket up near the pedal support, or attached to the wiper motor bracket.....Both these parts are more readily available thru a Cougar Parts Vendor....There are several on line that you should be able to purchase replacement parts from.  Good Luck.
