The big change was to the HP rating system which went from gross to net (more or less)
I have a 73 351C 4V, but in the past I had a 73 with the 302 2V and the FMX automatic.
I made the following changes that took the car from sluggish to more than respectable.
Carter AFB 4V Carb on Edelbrock Performer intake, Mallory Unilite ignition conversion, Mallory performance coil, Heddman headers and the most important change was to replace the center section of the rear end to change the gears to a 3.40 gear. This was all 20 years ago and some things are still the same, while others have changed.
If I was working with a 302 now I would use the GT 40 heads and a matching intake, a Holley with electric choke of 600-650 CFM with vacuum secondaries, I'd use Hooker headers as they seem to fit better, and I would probably go with 3.73 gears. I would upgrade the distributor to a HEI ignition and I have found none better than Performance Distributors out of Memphis.
If you are at the point of doing an engine rebuild a camshaft change will help. Roller cams free up horsepower, but I do not know if a roller block will interchange with your earlier style block. You would need to research that if you wanted to go in that direction.
I would actually consider going old school on the cam and using a solid cam-but you will need studs and guideplates added to the heads. It will give you an engine capable of running higher RPM's without valve float.
You might want to talk to some folks that are familiar with stall speed on torque converters and see if that needs to be adjusted to any changes you make.
