Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Contact
Login
Register
Forum
Ford Mustang forums
Mustang Discussions
Topic:
Exhaust manifold install- '66, I6, single exhaust
Pages:
1
Go Down
Author
Topic: Exhaust manifold install- '66, I6, single exhaust (Read 2903 times)
bandit1
Jr. Member
on:
September 04, 2010, 03:54:54 PM »
I'm replacing the exhaust system. I have some questions regarding the exhaust manifold installation.
Between the manifold (new) and head surface, should I use a new gasket or should I use something like Ultra Copper Maximum Temperature RTV Silicone Gasket Maker? I've heard some people say to use the gasket, and some say to use the RTV.
Also, what about:
Manifold bolts (new): threadlocker (red,blue)? OR antisieze? OR nothing?
What should I use to clean the threads that the bolts go into?
Manifold studs (new): threadlocker (red,blue)? OR antisieze? OR nothing?
Photo contest winner
Daily driver: 1969 VW Baja
Re: Exhaust manifold install- '66, I6, single exhaust
Reply #1 on:
September 04, 2010, 05:07:24 PM »
The intake manifold requires a gasket and if an exhaust manifold gasket came with your rebuild kit, I would use it, others would not - eh. I would not use any RTV or hi-temp liquid gasket maker stuff on the exhaust manifold.
If you want new bolts, try AMP Products
http://www.amkproducts.com/
for all kinds of hardware. The manifold kit has 22 items, p/n F-554, $18.00. I don't know what the 22 items are. There is a $30 minimum order.
Run a 3/8-16 tap into the hole to clean them up although it's not necessary unless the holes sat exposed to the weather or if there was a lot of crud when you took the old ones out. A high temp anti-sieze compound is OK, but not necessary. Don't bother with Locktite on anything other than studs and then use the red.
bandit1
Jr. Member
Reply #2 on:
September 04, 2010, 08:41:24 PM »
Ok. Thanks for the info. Here's some photos...
http://members.cox.net/steel3rivers/DSCN2385.JPG
http://members.cox.net/steel3rivers/DSCN2382.JPG
http://members.cox.net/steel3rivers/DSCN2387.JPG
Gender:
Reply #3 on:
September 09, 2010, 12:39:27 PM »
Those bolt holes look just fine. You may want to spray a little silicon spray in there, but otherwise don't bother. I would definitely use a gasket and get new bolts. Torque them to specs and not over tighten them.
bandit1
Jr. Member
Reply #4 on:
September 09, 2010, 02:08:57 PM »
Ok. Thanks.
bandit1
Jr. Member
Reply #5 on:
September 13, 2010, 01:21:17 AM »
I bought a new choke tube. How is it inserted into the new exhaust manifold? Is it press-fit or can it just be manually inserted? Also, it's difficult to get the tube angled properly to screw into the choke housing. I didn't want to try to bend it.
Reply #6 on:
September 13, 2010, 10:53:35 AM »
It's a force fit. If it's too loose, deform the tube "slightly".
bandit1
Jr. Member
Reply #7 on:
September 13, 2010, 02:53:06 PM »
Ok. Thanks.
bandit1
Jr. Member
Reply #8 on:
September 21, 2010, 05:39:45 PM »
I'm installing the exhaust system, but am having a problem. I had already tightened the manifold/head pipe connection, but not the head pipe/intermediate pipe connection or the right rear pipe hanger. The head to intermediate connection is as deep as I can get it (about 2 inches). I don't think it will allow any more. The muffler is hanging crooked. The intermediate pipe is about 1 inch too long to allow the muffler to be straight/fit correctly. Here are some photos. I guess I'll trim 1 inch off the head pipe (at the intermediate pipe connection). Any advice/info?
http://members.cox.net/steel3rivers/P10409101.jpg
http://members.cox.net/steel3rivers/P10409051.jpg
Reply #9 on:
September 21, 2010, 09:35:59 PM »
I think that the pipe at the muffler may not be bent correctly. That is not unusual for pipes as I had to take mine to a muffler shop to "improve" the bend over the rear axle (hint). Remember too , that almost all pipes are too long, eg, better to be too long than - -, you get the idea. That was another thing I had to do to get a descent fit and a saws-all (mine is a Dewalt) made that easy to do.
Jim.
bandit1
Jr. Member
Reply #10 on:
September 21, 2010, 10:29:36 PM »
Ok. Thanks.
Gender:
Reply #11 on:
September 22, 2010, 04:45:38 AM »
My sawz-all is one of the best tools I have in my shop.
zhuzhuxiao
Gender:
Mustang: fdgs
Daily driver: gh
Reply #12 on:
February 13, 2012, 02:15:34 AM »
______________________________
enjoy game so much!
wow gold
Buy Maplestory Mesos
WOW Gold
Pages:
1
Go Up
Forum
Ford Mustang forums
Mustang Discussions
Topic:
Navigation
Used Cars for sale
Ford Mustang classifieds
Powered by
EzPortal
