Author Topic: Blown head gasket, does anything else need replaced?  (Read 4828 times)
GT5.0stang
  • Mustang: 1991 Ford Mustang GT 5.0
  • Daily driver: 1991 Ford Mustang GT 5.0
« on: April 19, 2012, 03:26:13 AM »
My 91 mustang gt 5.0 has a blown head gasket, I am gonna change it out myself with a little help. before i did so I was wondering if there is anything else(gaskets, bolt, ext...) that will need or should be replaced while i have it apart?
Also if I were to go with upgrading the heads to "turbo swirl gt40 heads" it says i would need to upgrade the intake manifolds, headers, and valve covers, is that all? I recently installed some BBK shorty headers, would they be a good match? What manifold should I go with and
Thanks, Wes
ssparay
    • David Stanley Ford
  • Mustang: 1998
Re: Blown head gasket, does anything else need replaced?
« Reply #1 on: September 25, 2012, 01:16:54 PM »
Did you end up replacing any other parts while you had it taken apart?  Man, I've replaced head gaskets on every 90's ford I've ever touched!   ::)
true74yamaha
  • Mustang: 1964 1/2 coupe
  • Daily driver: 1985 chevy pick up
« Reply #2 on: September 17, 2013, 06:05:56 PM »
Take head to machine shop check to see if the heads are warped also check block when you pull them as well. I'm sure you probably know some dont so I let everyone know change both head gaskets not just one side
true74yamaha
« Reply #3 on: September 17, 2013, 06:07:26 PM »
I think with those head it maybe the gt 40p heads not sure but one of them has to have a certain type of header as the plug angle is different
