Author Topic: An A code engine in an 1964 1/2  (Read 16261 times)
rens81
  • Mustang: 1964 1/2
« on: March 05, 2013, 07:21:16 AM »
Dear All,
Can somebody help me with the following. I have a 64 1/2 (dating back to 6-1964 first admission) with VIN code 5R07A133839.
I thought that they A code engine was introduces with the 1965 mustang. Can somebody clearify this for me?
Thank you!
Rens
Topless_Horse
  • Mustang: 66 convertible
Re: An A code engine in an 1964 1/2
« Reply #1 on: March 05, 2013, 08:53:52 AM »
Welcome!
According to the database information (please see http://www.insearchofmustangs.org), the San Jose plant started producing the "A" code models somewhere around August of 1964.  The first "A" code VIN shown in the database, which does not show all VINs, is 5R07A125310.  This was about 8,529 cars before yours was built.
Your door dataplate should tell you what month yours was built but the database suggests it should have been either late August or early September of 1964
rens81
  • Mustang: 1964 1/2
« Reply #2 on: March 05, 2013, 09:58:23 AM »
thanks for the info mine was build september 64 :) which makes the date of admissiion a little bit strange :) But he if it is a 1964 mustang you don't hear me complain. I hope it concerns here a matching numbers car. Then it proves to me that it is all original.
Topless_Horse
« Reply #3 on: March 06, 2013, 09:37:12 AM »
I don't know if you're aware but for an early non-Shelby Mustang there is no such thing as "numbers matching" (at least not in the sense that the engine has the vehicle VIN stamped on it).  The best you can do is confirm that all the casting numbers match the date of manufacture.  The engine casting number is near the starter on the block, the head casting numbers are on the underside of the heads, and the bellhousing and transmission casting numbers should be on the sides of those units.
This website is a good place to look up the numbers as you find them:  http://www.mustangtek.com/index.html
Good luck!
rens81
  • Mustang: 1964 1/2
« Reply #4 on: March 06, 2013, 09:46:27 AM »
Thank you! :)
GeorgiaSnake
  • Mustang: 1992 Cobra
  • Daily driver: 2002 Sport Trac
« Reply #5 on: July 22, 2013, 04:02:03 PM »
Oddities sometimes abound.  I used to have a friend that had a concours 1965 "K" code GT.  His car was factory correct with the standard exhaust manifolds on his HiPo.  Seems the line was out of the HiPo manifolds the day his was being assembled.  Ford would not hold the line for such a detail and his engine was assembled with the standard manifolds.  Now I never knew how he proved this, build sheets maybe.
rens81
  • Mustang: 1964 1/2
« Reply #6 on: July 23, 2013, 01:54:47 AM »
Hi GeorgisSnake, thank you for your response. I can imagine a manifold being swapped when out of stock. But a whole different type of engine? Well it could be  ;D that's the whole fun. Do any of you guys know whhat can be wrong with my window sprayer. It is the stock one and doesn't squirt any water anymore. Any known problems? looking forward hearing from you. Have a good one!
GeorgiaSnake
« Reply #7 on: July 23, 2013, 04:29:46 PM »
Does the pump run?  Sometimes the nozzle will clog.  Try some light air pressure.  also introduce some rubbing alcohol solution as a solvent.
rens81
  • Mustang: 1964 1/2
« Reply #8 on: July 24, 2013, 02:24:20 AM »
Hi GeorgiaSnake, it makes noise. So it's not dead. But I will definitely try your suggestions! thanks a lot it's appreciated.
