Author Topic: 65 mustang master cylinder  (Read 6463 times)
65 COUPE
  • Mustang: 65 coupe
« on: July 24, 2013, 12:59:06 PM »
Hi . I have a 65 Mustang dual master cylinder, drum brakes.  My top cover doesn't  have the wire band to hold the top securely.  Mine is flat top with a screw holding the top on. I'm sure its not from a Mustang, because  I looked at all and nothing. Anyone have an idea what it might be from?
Topless_Horse
  • Mustang: 66 convertible
Re: 65 mustang master cylinder
« Reply #1 on: August 15, 2013, 06:09:05 PM »
Hard to say without a photo.  Can you post a couple of photos of what you have?
true74yamaha
  • Mustang: 1964 1/2 coupe
  • Daily driver: 1985 chevy pick up
« Reply #2 on: September 17, 2013, 06:01:07 PM »
Some styles on fiftys ford I know used a style similar to what your stating but again hard to tell without pictures. If I was you maybe your planning this which I would because not safe with out but. I would change your master-cylinder to a 1967 mustang manual master cylinder with drum drum option. Unless you want to upgrade to disc drum or disc disc in that case get a disc drum master. Same goes for if you want power set up. I would go to a power assist 67 master disc drum option or a power drum drum option if sticking with drums. Also a great booster choice would be a fox body 2.3l or 5.0 booster. Although you'd need to revise the brake Pedel pin because power cars use a different amount of force compared to non power. You would also want to reinforce the firewall and the Pedel support
65 COUPE
  • Mustang: 65 coupe
« Reply #3 on: June 05, 2014, 02:36:29 AM »
  OK and thanks  for the info  Here is a pic of the mastercylinder  Never seen anything  like it . It does have drum brakes
