Author Topic: 351CJ - Carb Issue  (Read 2007 times)
a_qcode
  • Measure the Man by the Size of His Horse !!
  • Mustang: 1973 Grande' Q-code 351CJ
  • Daily driver: 2010 F150 4x4 Super Crew XLT or 2006 Taurus SEL
351CJ - Carb Issue
« on: April 04, 2010, 10:20:49 PM »
 Can't keep my 750 Holly going.  It runs rough and won't idle.  It acts like I have a vacuum leak but i don't.  It won't ilde but is totally restored...  I am running basically stock cam lobe with a Offenhouser dua plane.  I just back fired and blew the power valve today. I put my lowly 600 Holly on it until I can figure it out.  why won't this carb idle?   My engine has only 3k miles on it..
Re: 351CJ - Carb Issue
« Reply #1 on: April 04, 2010, 11:40:54 PM »
Is that a 427 Cobra Jet engine?  If so, then you have just about the right carb.  Have you checked all the other tune-up issues like timing,etc.  If the carb was in good condition, I would  suspect other tune-up issues.  Now that the power valve has blown, I would tear it down and rebuild it, making sure the other timing issues have been resolved first.
« Reply #2 on: May 17, 2010, 03:01:58 PM »
Assuming you have a Q code 351 Cleveland like mine, let me make a suggestion or two.
Check the points in your distributor and check that the vacuum advance works freely. (unless the distributor has been converted, then just check that the advance mechanism is functioning properly.)
Check the cap for a crack or corroded terminals and check your wires for shorts. (Mine looked good, but would shock you in a heartbeat if you touched them when I got my car)
You can also test the coil to see if it is breaking down when hot.
I haven't mentioned checking the timing, but it isn't a bad idea.
My car had a 700 CFM Holley 4150 when I got it in basically stock trim with a 4 speed.  That was plenty of carb, now with closed chamber heads, a big solid cam, headers, very free flowing exhaust and a 5 speed-it is still plenty of carb for spin up to 7,000 rpm (though the dual points were only good for about 6500)
How is she running on the 600?  If she runs well on the 600 with no back firing or other bad habits, you may have a warped body in the 750, or some other damage.
Cleveland head ports are huge-as big or bigger than big block heads and they spin up higher RPM than most stock small blocks.  If the rear end ratio is 3.5 or lower or the car is a 4 speed, it may very well need a carburetor that is larger than conventional knowledge suggests.  Then again, that 600 might be just about right for a stock cammed automatic car with 3.50 or higher (numerically lower) gears
« Reply #3 on: May 18, 2010, 10:14:11 AM »
Okay I saw your other threads and suspect you know all the basics.  I can rebuild an engine and take carbs off and to a friend when they need rebuilding.  You car sounds pretty darn stout and I would love to know how you managed those 1/4 mile times with that set up as it is pretty close to mine and I can't come close to getting into the low 13's
« Reply #4 on: May 19, 2010, 07:13:01 PM »
He has a cobra Jet.
