Author Topic: 351C small block or big block  (Read 3931 times)
MarksMustang
  • Mustang: 1969 Mach One
  • Daily driver: 1969 Mach one
« on: February 12, 2011, 09:42:27 PM »
I am confused as to whether the 351C is a small block or a big block. I have a 69 Mach One clone that has a 351C. It needs all the power steering stuff, and I think there is a difference between those components for the big block cars..??? Thanks for any help with this!
TheJ
Re: 351C small block or big block
« Reply #1 on: February 12, 2011, 10:22:57 PM »
Simply stated it's neither. Here is some dimensions on a 351C among other motors.
http://home.comcast.net/~jelerath/mustang/engine/engine-fr.html#Weight%20and%20Width
hope this helps
jethat
« Reply #2 on: February 13, 2011, 10:29:46 PM »
Ford never used big block/small block terminology thats a chevy thing really. The 351c has the same bell pattern as the 351w so that would make it the same. The heads also will fit on a Windsor block with a special intake so that means it has more in common with the Windsors than any other Ford engine.
428CJ70
  • Mustang: 1970 Mach 1 w/ original 428CJ motor and Auto trans
  • Daily driver: '96 Pontiac Gran Prix GTP
« Reply #3 on: April 06, 2011, 01:21:22 AM »
Without heads and intake, the 351C is not much different in size than the 351W.  But the heads on the 351C makes it look like a smaller "big block" or maybe a fat small block.  I carried a 351C bare block (with mains) to my neighbors house 2 houses away when I was 16 so the block is not all that heavy.
Joe AZ 2 PA
  • Mustang: 1966 GT fastback
« Reply #4 on: April 06, 2011, 05:54:35 PM »
U-da-man. . . .  8)
Rat Fink
  • Mustang: 2011 mustang GT
  • Daily driver: 2011 mustang
« Reply #5 on: April 09, 2011, 06:22:05 PM »
in 1969 ford made 302, 351 (2)  390 428, and 429. 390 and428 are what ford calls the FE block.  302 and 351 Windsor are Windsor blocks. 302 Boss and 351 C are Cleveland blocks.  429 Boss is 429 boss. The "big blocks" would be 390, 428 and 429.
Joe AZ 2 PA
« Reply #6 on: April 10, 2011, 05:14:29 PM »
There also was a 351 Boss at some point in time. . . . . It was a good all around choice. . . . .  8)
Rat Fink
« Reply #7 on: April 10, 2011, 07:04:25 PM »
Boss 351 was in 1971
thundertc64
  • Mustang: 73 Mach 1 H code
« Reply #8 on: April 14, 2011, 04:36:09 PM »
if you want to get technical it is a small block. A Ford big block would consist of the FE/FT and MEL series engines 332/352/360/361/390/406/410/427/428/429/460/Boss 429/460
428CJ70
« Reply #9 on: April 14, 2011, 06:03:16 PM »
I have never heard a 302 BOSS block refered to as a "Cleveland" block, Cleveland style heads - yes, but not the block.  The 302 BOSS is not part of the 335 motors Cleveland series.  The block used in the 302 BOSS was a revised version of the 1968 302 TP (tunnel port) racing block with crossed 4-bolt mains (more like the 427FE motors).  I have always seen the 302 tunnel port motors more closely associated with the other 90 degree, Windsor family of motors.
