Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Contact
Login
Register
Forum
Ford Mustang forums
Mustang Discussions
Topic:
1973 351 2V Cleveland Won't Start
Pages:
1
Go Down
Author
Topic: 1973 351 2V Cleveland Won't Start (Read 3360 times)
a_eagles
Gender:
Mustang: 1973 Convertible
on:
September 03, 2010, 12:06:44 PM »
I'm new to this forum and look forward to contributing. Presently, I have a problem with the engine starting. Last time I started it, it turned over, fired, started, backfired, stalled and now won't start. So far I have done the following:
Checked gas to carburator - okay - won't start
Checked spark from plug in first cylynder - white/yellow spark visible - won't start
Installed Pertronex Ignitor and Flame Thrower Coil - won't start
Checked rotor position after cranking on first cylinder - okay
Compression (cold engine) in first cylinder is 115psi - not sure if this is enough or indicative of a timing chain slip - what is the expected compression? Intend to check the remaining cylinders compression as well.
After all of above, car still won't start. Any ideas of what to try next or what might be wrong are greatly appreciated
Sr. Member
Mustang: 1973 Mach 1
Re: 1973 351 2V Cleveland Won't Start
Reply #1 on:
September 03, 2010, 04:14:42 PM »
If the distributor has been out since it ran properly than it may be installed 180 degrees out
The Piston is at Top Dead Center matching the mark on the balancer TWICE in an ignition cycle.
Easiest way to tell is to turn the engine over (by hand) with the #1 plug removed and your thumb plugging the hole. When you feel pressure from the cylinder continue to turn the engine over until the timing mark is at "0"
If your timing is 180 degrees out, just move all the wires at the distributor 4 places over in the direction of rotation.
An ignition set up 180 degrees out will run badly and backfire when it will run at all.
115 PSI is a meaningless figure when taken from a cold engine with 7 of the 8 plugs in place.
proper compression for that engine is likely in the 140-150 range with the engine warm and all plugs out and spinning it with a fresh battery.
What you are looking for is a 10% or less variation from the best to the worst cylinder
a_eagles
Gender:
Reply #2 on:
September 04, 2010, 08:00:22 AM »
Jeff
Thanks for the reply.
I did the TDC check turning the engine by hand to line up the timing mark on two rotations. The Rotor position moved 180 degrees on each rotation and on the compression cycle stopped between the #1 and #3 wire lead from distributer. Turned the distributer to adjust rotor position, but with no success starting. Your advice re compression on cold engine is welcome news.
Car still won't start.
Sr. Member
Reply #3 on:
September 04, 2010, 10:28:20 AM »
How long has it been since it ran? If an extended time, the gas may be bad. You may need to have the carb rebuilt, but should be able to give it a shot of starting fluid to determine if it is a fuel related problem.
Also you still need to deal with timing. If it is cranking slow, it is usually retarded. One easy method if you have a friend available is to loosen the distributor enough to just be able to turn it by hand and then turn it a bit at a time while someone else cranks the engine. If your gas is bad, you will need to drain the tank, but until then you can run a small tank to the fuel pump and make sure that is the problem. Since a 73 doesn't have a fuel drain in the tank, draining the tank is a huge pain in the ass if it is full and as expensive as gas is, wasting 10 gallons or more isn't cool.
Was up in your city last month-enjoyed the Brass Rail LOL
a_eagles
Gender:
Reply #4 on:
September 04, 2010, 10:53:36 AM »
Hey Jeff...Glad to hear you enjoyed Toronto and the Brass Rail is a landmark for sure... I work about 10 minutes from there!
I used the car last Monday which is when the problem started. Had just filled with 94 octane gas which is what I have always used so that is not likely a problem. Got stranded with the car when it wouldn't start and had to have it towed home.
The Holly carb is no more than a year old.
Am going to try putting in new plugs, rotor, cap and wires to complement the Pertronix ignitor and coil switchover I did and see if that works.
Sr. Member
Reply #5 on:
September 07, 2010, 11:38:05 AM »
Okay, assuming carburetor and fuel pump/filter are all good then it is likely an ignition or ignition timing issue.
Has it run since you installed the pertronix? Does your coil have proper voltage? I know some of the converters require you to run a 12 volt lead instead of the reduced voltage point use.
If you just used the existing wire, you could burn up the module (but doubtful) If you installed an always hot 12 volt lead you would fry the coil.
I think your timing is off, but your spark could be weak. I like to see a fat blue spark, though lighting can make seeing a spark clearly difficult.
As I suggested before, I thing a loose distributor and a friend would get it started, simply by turning and listening, if the spark is strong.
Get out a multimeter and start checking voltage, both key on and key off. Substitute a known good coil if you have one, esp if you had the wiring wrong.
a_eagles
Gender:
Reply #6 on:
September 07, 2010, 01:47:42 PM »
Jeff
Pretty well tried everything including removing the timing chain cover and lo and behold as you can see in the pics, there is no evidence of a timing chain slip/skip, however there is some slack in the chain and I have ordered a new chain/gear assembly. Have tried to substitute the coil wire with a new one and it did not work.
To recap, we know we have gas to carb, we have spark which is yellow/white and probably should be blue (I am going to try an in-line spark tester to check all plugs but again, until this happened, no indication of a failure anywhere) rotor and timing chain at TDC appear sound, removed distributer and noted gear and pin are in solid condition.
It has not run since installing pertronix which was done to try and deal with this. I've heard since that pertronix isn't always the best thing so am thinking about going back to points and condenser until it gets running, then will try pertronix again.
Definitely perplexing! Any other thoughts are welcome.
Gender:
Reply #7 on:
September 09, 2010, 02:49:53 PM »
When I first installed my pertronix I left out the rotor. Wouldn't start. After slapping myself, I put the rotor on and she fired right up.
Pages:
1
Go Up
Forum
Ford Mustang forums
Mustang Discussions
Topic:
Navigation
Used Cars for sale
Ford Mustang classifieds
Powered by
EzPortal
