Author Topic: 1970 mach 1  (Read 2546 times)
  • Mustang: 1970 mach 1
  • Daily driver: 89 1/2 gt vert
1970 mach 1
« on: August 23, 2011, 01:03:58 PM »
i have a 70 mach one and am  what to make sure that it is what it is but things are not adding up from the vin it a h code and the door tag was not able to be read but what numbers that are there are diffrent now here the other thing the car is a non ac car has a org clutch peddle in it has the cobra clock org 428cj badge the big disk brakes up front the rear wing and front air valance the alum mach 1 side panals and cobra snakes on the side and the holes for the back window lovors i know the people that owned it before had a nother mach 1 at there desposal and the motor that is in it is a 351 c with 4v heads and a c6 trans
so i was wonder if there where any other numbers on the car to find out what it is
  • Mustang: 73 Mach 1 H code
Re: 1970 mach 1
« Reply #1 on: August 23, 2011, 09:59:27 PM »
I would recommend pulling off both fenders. The 1970 cars can either be on the front apron, forward of the shock towers, or on the top of the shock towers. Also i would look for the buck tag around radiator support by headlights ( although most buck tags can be removed with a screwdriver )The vin on the shock towers will only have the last digits of the vin number. But that would be a good start
