Author Topic: 1970 Mach 1 351w vin #'s  (Read 12462 times)
klessen
« on: January 31, 2007, 07:45:53 AM »
Hello, newbe here
I have a 70 mach 1 that we are trying to see if all numbers match. I do not have to door tag for all the info. has been cleaned off over the years. But I do have the dash vin numbers.
The dash vin is: 0F05H134285
I have also found the buck tag.
But I have found a number stamped on the engine in the area where a 429 would have a partial vin stamped. Now this is a 351W not a 429. The stamp is located on the rear face of the block just below the drivers side head.That number is (if I am reading it right)  9H598143. My question is would this engine be orginal to this car? I am the second owner to this car and was told everything is orginal.
Where are the other vin numbers located at on the car?
This car once finished will be a show car only and driven just to shows. But I would like to display all numbers on the car. As we are rebuilding the engine I am locating all casting numbers and dates. What would be a good why to display them?
We also have a 63 galaxie that my husband has beef up so there is nothing orginal to the car except the frame and the inside of the car. So I can not do this to that car.
Any help on this would be greatly appreciated.
Krista Lessen
  • Administrator
    • Used cars
  • Daily driver: Sunfire
Re: 1970 Mach 1 351w vin #'s
« Reply #1 on: February 01, 2007, 02:32:29 PM »
Welcome to the site Krista.
Without the door tag we can't find much information about your car but this is what I have found with the number you gave us is:
Year:     0     1970
Plant:    F    Dearborn, MI
Body Series:   05   SportsRoof, Mach 1
Engine:    H   351 2v V8
Unit:    134285    134285
The engine number 9H598143 shows that it's a 351 (H) manufactured  in 1969 (9) so it could be the original one. You can purchase a Vin decoder disk. I never tried it but it seems very usefull.
http://www.mustangdecoder.com/disk.html
Good luck and if you want to show your Mustang in its actual condition, please feel free to do so.
Russ
  • The one to watch for
  • Mustang: 1973 FORD MACH ONE
« Reply #2 on: February 18, 2007, 10:42:17 PM »
Does that state that it is the 351 C with either 266 or 277 factory horses?
Jerry Baker
« Reply #3 on: February 19, 2007, 10:45:14 AM »
The book I have says that it should be a 351C thats was the new motor for 70 and that the 351W was deleted from the line up.  Its said that the 351C with 300hp replaced the deleted 351W 4 BBL.
« Reply #4 on: October 18, 2008, 06:14:33 PM »
I have a 351W in my 1981 Ford F-150 Ranger pickup.  So, it is quite clear that the 351W was put into a lot of applications through the early 1980's.  They are, and will continue to be "dog" engines, but they pull like a Mofo, so have a ton of torque.
« Reply #5 on: October 18, 2008, 06:16:58 PM »
 Gas mileage is only 10-12 MPG though.  A guzzler for sure.
calypso coral
  • Mustang: wanted:70 Mustang fact. Calypso convert project
« Reply #6 on: September 26, 2009, 11:10:03 AM »
351 W 4v was deleted from 1970 Mustang lineup. The 351 W 2v was not and is very common.
Just go to martiautoworks and for $17 you can find out all the options your car came with.
