Author Topic: Wrenchin’ Tip for 10-14-10 Back Cut your Intake Valves  (Read 1631 times)
timsweet
  • Mustang: 1970 Coupe
  • Daily driver: 2007 Corvette
« on: October 14, 2010, 09:39:53 PM »
http://timsweet.wordpress.com/2010/10/14/wrenchin-tip-for-10-14-10-back-cut-your-intake-valves
Filed under: Auto Body Work, Auto Cross, C4, Car Art, Car Parts, Car Restoration, Car Shows, Cars, Chevy, Chrysler, Corvette, Dodge, Dodge, Drag Racing, Engine Mods, Ford, MOPAR, Muscle Cars, Mustang, Plymouth, Pontiac, Restro-Mods, Street Racing, Suspension Mods, Uncategorized by timsweet — Leave a comment
October 14, 2010
If you are work on your older cars engine, there are a good many tricks that you can use save a couple bucks and gain a little horsepower.
This one is an oldie but a good.
Have your intake valves back cut, you’ll get a similar boost as if you use high lift rocker arms or cam.
The procedure is best done by a qualified machinist.  So while you have your engine apart and laying all around our garage on pieces of cardboard (come…you know that’s what happens!!!) have him take a little off the port side of your intake valves.  This creates the same effect as an earlier opening a later closing action like  just a like a the addition of a an upgrade cam.  The lighter valve means less spring pressure is required to control the valve at higher rmps.
A 30 degree cut is what they do on vortex engines.
The backcut is at the edge of the normal valve cut.
Thanks for reading.
Tim
