Author Topic: Wrenchin’ Tip Engine Swap 8/8/2010  (Read 1138 times)
timsweet
  • Mustang: 1970 Coupe
  • Daily driver: 2007 Corvette
« on: August 08, 2010, 09:56:22 PM »
At some point I’ve promised myself I would cover the restoration stories that center around my 1970 Mustang.  There is a lot to tell, trust me!! I’ve learned a lot!!!
Engine - Before (250)
Engine After - (302)
But for this Wrenchin’ Tip, I’d thought I’d share a few hints that I did pick up.  Just to be fair I didn’t  do a lot of the engine swap work myself (Average Guy w/ average tool and average skills) but I learned a lot of general helpful hints and some Mustang specific helpful hints!!!
So here are a couple of tips:
 1.  Planning and scheduling a restoration is important.  If you are doing an engine swap or pulling it out for an overhaul make this the first step in your restoration.  Yes, I’ve seen the TV shows where they put the engine after the car is back from the body shop.  But hey this is the real world, and in this world, money is tight and body work is expensive enough not to what to afford to re-do it.  In this world, my average guy world, wrenches slip, grease stains and sometimes swinging 400 lb engine at the end of a chain can be…well…a bit dicey.
2. Before preparing the engine for removal, you know, disconnecting all the electrical, fuel, A/C,  vacuum system, etc., take the hood off and store it someplace safe.  You’ll have a ton of room and you won’t bounce  that shiny, newly painted engine against it.
3.   Test fit the headers before you install the engine, especially if you aren’t putting stock headers back on.  You need to check the clearances around them and ensure you can get to key components , such as starters, after the engine is completely installed.  Nothing is more insane that having to pull an engine or headers just to replace your starter. Here is a pic of my Mustang’s engine with all the attachments.
Clearance checking pre-fit!!!http://timsweet.wordpress.com/2010/08/08/wrenchin-tip-engine-swap-882010/
More engine swap tips coming up.
Thanks for reading.
Tim
Re: Wrenchin’ Tip Engine Swap 8/8/2010
« Reply #1 on: August 08, 2010, 11:44:28 PM »
Thanks Tim...that's good info.
