First: take out the drivers seat; remove the console (if you have one); remove the radio; remove the ash tray; remove the defroster ducting; thar she be, up there. There are four 1/4-20 bolts holding the bracket to the underside of the dash. Don't forget to disconnect the motor arm from the wiper arm bar. Remember, the single speed is different than the two speed - switch, wiring, motor. There is a circuit breaker internal to both types and it is not repairable. My used parts guy is not home right now so I can't get you a price.
