Author Topic: Will Maverick disc brakes fit my 68?  (Read 4793 times)
lenniesdad
« on: April 19, 2008, 07:11:19 PM »
A buddy is parting out a 75 and 77 Maverick with power disc brakes and power steering. Will it bolt to my standard 68 Coupe, spindles and all? How about the Grenada? I have heard the front disc brakes are bolt on swap. Any advice?
Re: Will Maverick disc brakes fit my 68?
« Reply #1 on: April 19, 2008, 09:40:33 PM »
I have done some research for you, now continue to answer you own question.
 XI. BRAKES:
How to bleed the brakes:
http://www.sandiegomiataclub.org/SDMC/Garage/Brake_Fluid.html
How to change your brake shoes:
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1c/41/de/0900823d801c41de.jsp#hd1-1-1
Brake wheel cylinder replacement or rebuild:
http://autorepair.about.com/cs/doityourself/a/wheel_cylinders.
Granada Disk Brake Swap with new parts- by Dennis Ginsberg
http://www.discbrakeswap.com/The_Granada_Swap_Guide_03.19.3006.v01.pdf
Granada Disk Brake Swap:
http://www.midnightdsigns.com/james/Disc%20Brakes.htm
Granada Disk brake swap and Shelby drop:
http://www.geocities.com/MotorCity/Downs/1966/granada.html
Another very good Granada brake swap guide:
http://www.midnightdsigns.com/james/Disc%20Brakes.htm#Installation
Drum to disk brake swap:
http://www.woodyg.com/fairlane/finfo/drumtodisc.html
Granada disk brake swap: By 2bav8
http://www.geocities.com/2bav8/granada.html
How to install Power front disk brakes:
http://mustangmonthly.com/techarticles/mump_0605_1967_ford_mustang_disc_brake_install/
How-To convert to disk brakes for 6 cylinder Mustangs and keep your 4 lugs:
http://www.mustangmonthly.com/howto/17279/index.html
How to install and tune a proportioning valve:
http://www.chevyhiperformance.com/techarticles/71398_install_brake_proportioning_valve/
Rear disc brakes: http://www.classicperform.com/tech_articles/rear-brakes/rear-brakes-tech.htm
How do I stop my disk brakes from squeaking?
http://www.aa1car.com/library/2004/bf80426.htm
  • Administrator
    • Used cars
  • Daily driver: Sunfire
« Reply #2 on: April 20, 2008, 06:48:52 PM »
 Welcome to the site Lenniesdad. Soaring's reply comes from his classic Mustang FAQ. You may want to check it as there might be an answer to any question you can have.  ;)
