Author Topic: will a 302 fit on a 289 tran  (Read 3953 times)
racingjz
  • Mustang: 1965 coupe
« on: April 01, 2010, 04:28:51 PM »
looking at a 302 for my 65 mustang the 289 is almost gone i want to do a rebuild but want to have more power with out messing with the cars stock 289 will that trans fit the 302 or do i gots to get a new one? thanks joey :o
Re: will a 302 fit on a 289 tran
« Reply #1 on: April 01, 2010, 04:41:07 PM »
Everything is interchangable.
« Reply #2 on: April 01, 2010, 05:13:51 PM »
Try to find a 302 that was used in the late 60's or early 70's, casting no's C8OE-6015-A & B, C8TE-6015-B preferred. Later blocks (casting dates starting in 1973) were cast to provide a lower compression ratio. Just about all the parts will fit but the 289 crank and rods may (I say may, I don't know) hit the lower cylinder skirt. Remember that early 1965 289 engines were 5 bolt to the transmissions, so find out your casting number first. If you look athe the lorer right hand block where the starter goes, you will find the casting p/n. If it's a C5AE-6015-E p/n you are OK. A C4OE-6015-C or F are 5 bolt types.
racingjz
« Reply #3 on: April 02, 2010, 04:31:56 PM »
thanks thats what i needed to know
ol dirty doug
  • Ol' Dirty Doug
« Reply #4 on: April 03, 2010, 03:14:58 PM »
what about a 89-91 gt motor? they have 302 cid(5.0) fordged pistons and roller cam stock! that would bolt to the 289 c4 won't it? they're cheep and make good power stock.
racingjz
« Reply #5 on: April 03, 2010, 06:08:28 PM »
it should as long as the bell housing size and number of bolts are the same i found a c4 from summit that has a smaller bell housing
« Reply #6 on: April 03, 2010, 06:52:13 PM »
Why would you need a smaller bellhousing to fit the original C4?  Better check into that further.
