Okay heres what I have ran across. I have done the finger over the #1cly hole and when it blows back and forces my finger off, I'm at TDC correct? then I was told, slowly with a socket move the balancer to 0, my balancer had 2 rows of # which to I use? heres what is causing all the problems. When I think I'm at TDC the rotor wont go anywhere near the #1 cly and the mark on the distrbutor,the vac advance stops any rotation that far, so I moved the #1 wire to the correct position on the cap and put the Rotor/marks and wire at that aligning point. So I was at #1 TDC and 0 on the balancer and the rotor lined up with the #1 plug wire. The engine just cranks and does not turn over. Anybody in Indy can help ? LOL
