Thank you. You wouldn’t by chance know how much more they weigh do you? My engine makes 550 lbs. torque @ 3,000 RPMs, and I can’t afford a custom 31 spline setup, so I like idea of the Lincoln’s heavy duty rear end housing & axles and the added weight on the rear tires to help with hookup. However, I am worried about the extra unsprung weight that the rear end will add. It will also have stiffer rear springs. I don’t want the car to skate into a drift in autocross and road racing conditions. I’m going to relocate the battery into the trunk to help the body of the car fight tire bounce, but I don’t know if that will be enough to offset the bounce energy that the rear end will generate. What do you think?
