Author Topic: What do you think?  (Read 1666 times)
stephane
  • Mustang: 68 coupe
What do you think?
« on: September 01, 2010, 08:22:49 PM »
Since I need to change the transmission in my 68 coupe,  the question is AOD or C4. I have 1 of each in the garage. Give me your pros and cons. Thank you.
Stephane Leger
Re: What do you think?
« Reply #1 on: September 01, 2010, 11:00:29 PM »
First question is "change" from what? If it's a swap, the C4 would be the easiest. An AOD requires a  modified drive shaft, modified rear mount, modified shifter, kickdown, speedometer cable (and gear), electrical and vacuum connections and the most important item - time. There are other items, bell housing, flex plate, starter etc. Can it be done? Sure.
« Reply #2 on: September 02, 2010, 07:33:43 AM »
Yeah Stephane, let us know what transmission you have in there right now.  It could be as simple as repairing the one you already have.
stephane
  • Mustang: 68 coupe
« Reply #3 on: September 02, 2010, 09:18:24 AM »
I have a C 4 in there right now, but I don't like the high revs on the highway, and I don't know if I want to give up my 350 rear end
jethat
« Reply #4 on: September 18, 2010, 12:21:52 AM »
I would convert it to the AOD if it were me. I'm a glutton for punishment though. Sticking with the C4 would be much easier. Unless your really good with a wrench thats the thing you should do. Paying someone to do all the work would get expensive so rich or good with a wrench do the AOD if not stick with whats in there.
