« Reply #2 on: May 26, 2008, 05:13:37 PM »
okay bro, set back and let me walk you threw what I did. First, I got me a nice 32 oz. bud light, and drank it. Then after that I choose too remove that ugly thing. After you take everything to include trim off you will see resido all that will come off with 80 grit. Now, the little strip that is on your window strip( the piece that are just to the outside of the front window) you should remove the drip caps so you can really get down and get it clean, you will be happier in the end. I tried to leave them on and in the long run I scratched the drive side and had to take them off anyways, so save yourself and remove them prior too. Once all the glue was removed I use a die gringer and shave those tips off the middle of the top. You will find that the glue comes off a lot slower than just paint itself but once you get it off you will really like what you get. Let me know....
