Author Topic: valve adjustments  (Read 3991 times)
jonlyjayman
  • Mustang: 1971 mach 1
valve adjustments
« on: November 19, 2009, 11:14:39 PM »
  Hi-  New here and need advice on "ticky" valves. It's a 71 Mach1. TKO 5 speed, bought it 4 yrs ago, it runs great,great power. Engine is not stock. 351C 11:1 compression, 4v heads, screw in studs, roller tappets, hydraulic lifters.
    I had some "ticking" in the valve covers so I thought I'd pull valve covers for the first time since owning the car. Basically I could shake around every rocker arm and tightened them all, while having the opposing valve in each cylinder open.
    The ticking has not gone away, maybe slightly worse, but car idles much better-(better Vacuum?).
    What the heck am I doing? I'm really not too sure how to proceed, but I'm not afraid to get in there. Valve covers way easy to remove. Should motor be warm? What about hydraulic lifter pumping up?   is there a good article that covers these adjustments?  Thanks
lovehamr
  • Mustang: 70 Boss 302, 88 Saleen, 65 Cobra replica
Re: valve adjustments
« Reply #1 on: November 20, 2009, 02:08:50 PM »
Shouldn't be a big deal man.  I do valves going by the firing order and adjusting each at what would be TDC on that cylinders compression stroke.  I have a Dizzy cap cut in half with the cylinders numbered in the proper order so when the pointer in the dizzy is pointed at say cyl.#3 that will be the intake and exhaust valves that I adjust.  Or you can start at TDC compression on number 1 cyl. (Pointer at "0") then just rotate the crank 1 quarter turn clockwise to get to the next one in the firing order and just work it all the way around.  At each cylinder start spinning the pushrod with your fingers and feel for drag as you tighten the rocker nut, when you first feel drag on the pushrod tighten the rocker nut 1/4 turn more and lock it at that point.  This is to get the hyd. lifter's piston in the center of it's throw so that it can function as it should.  Do this for all 16 and the world should be aligned.  Let us know what you find because if you wind up with some wild funky adjustments it could mean other problems like collapsed lifters or flattened cams.
Hope that helps, Steve
jonlyjayman
« Reply #2 on: November 20, 2009, 05:40:50 PM »
  Thanks for the reply steve. I'm not sure what a Dizzy cap is, and I don't have any fancy tools. What I tried to do was work off 1 head at a time. To get a valve fully seated, I was turning motor with big ratchet on the front pully. I watched the other valve-in the same cylinder- and when 1valve just barely starts to move, the other is fully seated, correct?  (does overlap throw my idea off??). at this point I should do as you stated and twist pushrod, going 1/4 turn past it beginning to drag. How do I lock the nut? or just leave it 1/4 turn past?
    My described method of insuring valve seated fully..... is the only way I can think of to avoid having to find TDC on compression stroke.  Is there an easy way to find TDC which is time both valves fully closed???
    Thanks steve, jay
lovehamr
« Reply #3 on: November 20, 2009, 07:56:46 PM »
  Sorry Jay, that's short for distributor cap.  I just sawed the top off so the rotor would show what cylinder to work on.
No.  ;)
Yes. ;)
If you are using the factory lock nuts then just leave them in the right position.  If they are old and easy to turn then you may want to look into poly locks to make sure the rockers stay where you want them.
    Thanks steve, jay
Start by putting a mark on the dist. housing below the cap and lined up under #1 cyl plug wire.  Then with the cap off, rotate the crank so the rotor is at that mark.  Then look down at the timing pointer, it should be only about 15 degrees or so from zero.  Then use your big rachet again to rotate the crank so the pointer is at zero on the damper.  Now you're at TDC compression.  If you really want to check, both valves should be seated and you can pull the #1 spark plug, use a screw driver gently through the hole to feel for the piston (it'll be there ;)).  Then adjust #1's valves.  After that all you have to do is rotate the crank 1/4 of a turn to do each subsequent cylinder in it's firing order.
Steve
lovehamr
« Reply #4 on: November 20, 2009, 09:55:00 PM »
I just noticed this and have to ask.  You state "roller tappets" then "hydraulic lifters".  Tappets and lifters are the same thing.  Do you mean roller rockers?  If so then you should already have poly locks.  So look at these sites and if you still have questions don't hesitate to ask.
http://www.pontiacpower.com/faqs6.htm
http://www.kustombitz.com/UserFiles/2024-Files/file//YellaTerra%20Brochure-PosiLocks-rocker-studs-pushrod-guide-plates.pdf
http://www.mustangsandmore.com/ubb/Forum12/HTML/006804.html
Steve
jonlyjayman
« Reply #5 on: November 20, 2009, 11:26:49 PM »
By roller tappets-I mean when valve covers are off, and I mess with the rocker arms-there are small rollers that push down on valve stem. I emailed the guy I bought car from and he said they are hyd. lifters--not solid lifters. Am I using the wrong phrase? I remember an old v8 I owned-72 Grande 302...and it had no roller on rocker arm....just metal on metal pushing down valve stem. What do I have?   Thanks Steve...........Jay
lovehamr
« Reply #6 on: November 20, 2009, 11:55:16 PM »
You've got roller rockers and flat hydraulic tappets.  There are several types but that really doesn't matter right now.  What is holding them on the stud?
Steve
jonlyjayman
« Reply #7 on: November 24, 2009, 05:36:32 PM »
   the rocker arms are held on with a half-circle looking thing, then a nut on top of that.........the half circle thing is sitting inside the hollow part of rocker arm.  Thanks for your help steve, I really am not a huge car guy--just love mustangs.
jonlyjayman
« Reply #8 on: November 24, 2009, 05:45:49 PM »
    Also Steve....Should I drive the car to get oit all warmed up before adjusting the valves?   Or is cold engine OK<  Thanks,  Happy ThanksGivin'     Jay
lovehamr
« Reply #9 on: November 24, 2009, 06:06:37 PM »
First, cold is fine.  Is there any way that you van post a pic of your rockers?  Or do they look like one of these:
or one of these?
The ones on top should have this type of nut with lock;
And the lowers would look like this:
jonlyjayman
« Reply #10 on: November 27, 2009, 10:20:05 AM »
 Mine look like the second ones, and the last picture looks like the nuts that hold mine on. I'll probably get to doing them next week as I'm visiting my parents in NY. And if cold is okay, I'll just do it cold. Once it's all done correctly, it should have minimum "tick", correct? Assuming I have no other problem?
  Thanks Steve................Jay
lovehamr
« Reply #11 on: November 27, 2009, 12:54:06 PM »
Yup.
« Reply #12 on: November 27, 2009, 04:48:27 PM »
Just in case you don't know how to adjust those hydraulic valves Jon,  here is a simple guide.  If the ticking continues, then just turn up the radio volume.   ;D
http://raceabilene.com/kelly/hotrod/valveadj.html
lovehamr
« Reply #13 on: November 27, 2009, 06:29:41 PM »
Dude's name is Jay.
« Reply #14 on: November 27, 2009, 06:58:28 PM »
Sorry 'bout that.  Jay it is....
jonlyjayman
« Reply #15 on: November 27, 2009, 10:22:48 PM »
you can call me Ray, You can call me Jay.......or Jon...
  I just apprecite the help.
« Reply #16 on: November 28, 2009, 08:03:16 PM »
 ;D Reminds me of an old song.   ;D
lovehamr
« Reply #17 on: November 28, 2009, 08:37:01 PM »
......................."But ya dosen't have to call me Johnson!" ;D
I can't remember the name of the comedian that used to do that bit.   I'm afflicted with CRS. ???
Last post February 04, 2010, 07:36:27 PM
by ol dirty doug
Last post May 30, 2008, 01:17:49 AM
by Oz66FB
Last post July 28, 2009, 03:20:46 PM
Last post August 09, 2009, 04:58:29 PM
Last post April 23, 2011, 11:28:39 PM
by mustang15
