Author Topic: Value added/lost in upgrading to electronic ignition  (Read 1217 times)
nccochrane
  • Mustang: 1966 Mustang Coupe
« on: December 04, 2011, 09:06:16 PM »
I am considering buying a 67' coupe to restore.  Everything is original and only has 43k miles. The owner installed electronic ignition, which I assumed helped performance. However, I want to restore to original specs as best as I can. Will leaving the electronic ignition in reduce the value should I sell it in the future?  Would it be better to overhaul the 289?  Thanks in advance.
Topless_Horse
  • Mustang: 66 convertible
  • Daily driver: Ram 2500
Re: Value added/lost in upgrading to electronic ignition
« Reply #1 on: December 05, 2011, 08:09:49 AM »
It depends on what kind of electronic ignition and your intended use of the car.  If you will be showing the car as an unmodified vehicle the Pertronix ignition conversion is not cause for an MCA points deduction.  But if you intend to drive the car quite a bit then any electronic conversion is worthwhile because it reduces maintenace (no points to replace and adjust every few thousand miles).
The decision to overhaul the engine should be based on the condition of the engine.  If the oil pressure and compression are OK and there are no other major issues with it (smoking, knocks, etc.) then I would not touch it.
nccochrane
« Reply #2 on: December 05, 2011, 06:39:55 PM »
Thanks. I realized after I posted that when I said it has 43k miles, that is what the seller told me. He is the 3rd or 4th owner.  However, how can one verify the mileage? Couldn't it simply be 143k? I don't think he has any paperwork on it except for the current title.
Also, how many 67's came with A/C?  This option is not on it and I again am thinking about resale value down the road?
Topless_Horse
« Reply #3 on: December 06, 2011, 08:01:47 AM »
About the mileage - it's really difficult to know whether the mileage is correct but if the underside is still painted and is intact then it's possible that it does only have 43k.  Verification is something you have to address with the seller - he's responsible for proving his claims.  If he can't then you're not required to believe him and can either adjust your offering price or walk away.
I don't know the production numbers for cars with AC but they're probably out there somewhere on the internet.  It will be a fairly big and expensive project if you want to add it to make it look like a factory installation because starting in 1967 Ford integrated the AC with the heater.  This means that for the factory-installed AC, there's a specific heater box, specific heater & a/c controls, vents integrated in the dash, etc.
I'm sure that there were also dealer-installed units that hung under the dash (like the 65-66) as well but I doubt you'd be able to find "production numbers" for those and although the installation might be "correct", it would not look as good as the integrated factory unit.
To be honest, I don't think that having AC is going to add a lot of resale value.  The value is more dictated by the body style, engine, transmission and overall condition.  But again, if you intend to drive the car often and you live in an area that has a lot of hot humid weather, then it's a good deal if it improves your comfort.
