Unfortuntely, neither caculator tells you what new speedometer drive gear you might need to change. In general (looking at my notes), a larger diameter tire (tyre for the guys down under) means less teeth in the transmission's cable drive gear, and a higher gear ratio (as in 3:00-1 changed to 3:89-1) would require more teeth. I use two methods, my GPS receiver (it's a bit more sophisticated than a Garman) that reads direct mph, or a stopwatch and roadside mileage markers. Go exactly 60mph for one mile (more than once for accuracy) and you should clock 60 seconds. More time you're slow, less time you're fast.
