Russ,Is your engine disassembled or not? I am a little confused with your question? If still assembled and you want to take the rust off the exposed parts of the block and intake manifold use a drill and wire brush to do it. Then go buy a good quality high temp engine paint from your local NAPA parts store. I just did my 67' and it really came out nice and so far seems to be holding up under operating heat the engine generates. NAPA stocks the exact paint for the different year Fords which used several colors and shades of blue.Hope this helps.Jeff
NEED TO FINE OUT WHAT IS THE BEST WAY TO REMOVE RUST FROM THE HEAD PASSAGE WAYS AS WELL WITH THE BLOCK. That THANK YOU ALL FOR YOUR TIMEESPECIALLY FOR A FIRST TIMER AS MY SELFJUST GOT THE CAR THIS SUNDAYRUSS
