Author Topic: Replacing wire from coil to distributor  (Read 2706 times)
JimC
  • Mustang: 1966
« on: October 01, 2009, 04:51:12 PM »
My son and I are attempting to restore a 66 mustang. While replacing a faulty coil, the lead from a wire that runs from the (-) terminal to the distributor broke off. I assume I need to replace this wire, but am not sure how to remove it from the distributor. Any suggestions would be appreciated.
Jeff1967
  • Mustang: 1967 convertible
Re: Replacing wire from coil to distributor
« Reply #1 on: October 02, 2009, 05:03:56 PM »
Jim,
While working on my 67' last winter the same thing happened to me. Look at the attached image (sorry a little blurry) but the wire should be the same. The rubber grommet can be pushed back into the distributor housing and removed with the wire. I went to the local junk yard and found the exact gauge wire that included the 90 degree rubberized connector that clips onto the coil terminal. Then I took a razor blade and cut the rubber grommet off the original wire carefully so I could re-fit it in the proper position on the new wire. Then I took a knife blade and carefully removed the 1/2 moon wire connector on the other end of the wire and re-clamped it to the new wire, totally reproducing the old wire.
Hope this makes sense and works?
Jeff
JimC
  • Mustang: 1966
« Reply #2 on: October 03, 2009, 01:54:25 PM »
Thanks Jeff. It was very helpful.
Last post December 18, 2006, 10:34:37 AM
by Ken Moore
Last post January 05, 2009, 09:27:00 AM
by crzylx
Last post April 15, 2009, 05:15:52 PM
by foreverandcounting
Last post June 07, 2009, 03:25:12 PM
Last post March 03, 2010, 07:01:21 PM
by ror_schach
