Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Contact
Login
Register
Forum
Technical forums
Topic:
rear shock length
Pages:
1
Go Down
Author
Topic: rear shock length (Read 9515 times)
Oz66FB
Jr. Member
rear shock length
on:
May 13, 2008, 10:18:32 PM »
hi guys,
anyone able to help?
thanks
Oz
Gender:
Re: rear shock length
Reply #1 on:
May 14, 2008, 06:55:50 AM »
Nah, my KYB's are on the car. Why do you need that measurement?
Photo contest winner
Daily driver: 1969 VW Baja
Reply #2 on:
May 14, 2008, 11:29:47 AM »
Oz66FB
Jr. Member
Reply #3 on:
May 14, 2008, 06:13:49 PM »
I couldnt get accurate measurements and the best answer i could come up with is that the shock needed to be 11.75" compressed including the inside rubbers. Givent the old ones were around 12.8 this didnt seem right. The car is lowered but only about 3/4", so the shock travel would be reduced by less than that and the fully compressed measurement should stay the same as it is determined by the bumpstop contacting the axle housing.
thanks again for your help
Reply #4 on:
May 14, 2008, 06:50:19 PM »
Ben,
Oz66FB
Jr. Member
Reply #5 on:
May 14, 2008, 08:05:20 PM »
thanks Jim
Which Cab?
Gender:
Reply #6 on:
May 15, 2008, 09:37:52 PM »
Hey Ozzie....I guess you figured out where to come for good advice.
Jim and Stephen know a few things about our old mustangs don't they? It's good to see you on here. I didn't realize that 3/4 of an inch made that much difference in the performance of a shock, but since you are into roundy round racing, I suppose you know what you are talking about. How's the weather down under? We've been having some 70-80 F and a lot of rain here in central Texas.
Oz66FB
Jr. Member
Reply #7 on:
May 15, 2008, 09:48:06 PM »
too true Glen
Reply #8 on:
May 16, 2008, 11:54:26 AM »
Ben,
Oz66FB
Jr. Member
Reply #9 on:
May 18, 2008, 09:28:50 PM »
Reply #10 on:
May 19, 2008, 10:53:05 AM »
Oz66FB
Jr. Member
Reply #11 on:
May 19, 2008, 06:11:37 PM »
Oz66FB
Jr. Member
Reply #12 on:
May 19, 2008, 06:14:04 PM »
hope this works
Oz66FB
Jr. Member
Reply #13 on:
May 19, 2008, 06:14:38 PM »
http://www.autopics.com.au/cache/item-3740public.html?cache=no
Gender:
Reply #14 on:
May 20, 2008, 11:33:27 PM »
Great pics Ozzie. It shows you how far we have come in the last 40 something years.
Oz66FB
Jr. Member
Reply #15 on:
May 20, 2008, 11:57:02 PM »
http://www.touringcarmasters.com.au/photogallery/rnd2_gallery.htm
flick left arrow backwards to pic 40. That was 27April this year!
Gender:
Reply #16 on:
May 21, 2008, 04:56:12 PM »
I love them too. Great shots. Even the bowties look good.
Pages:
1
Go Up
Forum
Technical forums
Topic:
rear shock length
Navigation
Used Cars for sale
Ford Mustang classifieds
Powered by
EzPortal
