Author Topic: Rear End  (Read 2057 times)
Jeff1967
  • Mustang: 1967 convertible
Rear End
« on: September 05, 2010, 06:07:27 PM »
My 67' has an 8" rear end and it has started leaking lube where the drive shaft enters the rear end. I assume there is a seal there, is it possible to change without a lot of effort? or should I have a shop look into it? I have the ability to do some work if it does not involve rocket science.
Advise would be appreciated .
Thanks
Jeff
Re: Rear End
« Reply #1 on: September 05, 2010, 11:22:00 PM »
Because you need special tools, and to set the lash, take it to a shop. Otherwise you get a nasty "whine".
Jeff1967
Re: Rear End
« Reply #2 on: September 05, 2010, 11:58:32 PM »
I will do that, thanks for the advise.
JJ
Re: Rear End
« Reply #3 on: September 09, 2010, 01:25:48 PM »
And, when the shop is through replacing the seal, have them fill the rear with synthetic 75-W-90 gear lube.
Jeff1967
Re: Rear End
« Reply #4 on: September 09, 2010, 05:27:09 PM »
Glen,
Thank you for the advise I will do that.
Jeff
Re: Rear End
« Reply #5 on: September 10, 2010, 04:31:20 AM »
That stuff is slicker than snot on glass.  I have it in my transmission and in my rear.  My gas mileage improved drastically after I had that old black 90 weight dino gear lube drained and replaced with synthetic.  It's a messy process if you try to do it yourself though.  I took mine to a Jiffy Lube place.  Seems like it was like $65 bux.
