Author Topic: Quarters spare change  (Read 1790 times)
my71mach1
« on: August 25, 2009, 09:18:36 PM »
Ok this has been driving me nuts at around 1500 rpm I hear what its like to be spare change jingling
I jacked up the car and looked I didn't see any loose bolts on the undercarrage it seems maybe the exhaust but all the clamps and hangers are tight.
any one else have spare change jingling on there 71/72/73 or any other year..
Thanks
Re: Quarters spare change
« Reply #1 on: August 26, 2009, 12:11:43 AM »
Sounds almost like its something to do with your front steering pieces. Either maybe it needs to be aligned or, some or all of the bushing or bearings are bad/need greasing. Never heard of this before though, good luck.
my71mach1
« Reply #2 on: August 26, 2009, 07:36:26 AM »
I rebuilt the front end parts that was the first place i looked i thought it was the sway bar end link bushing  ???
« Reply #3 on: August 26, 2009, 07:50:10 AM »
Not sure what it is, but I had a car that did the same thing and it was the catalytic converter heat shield vibrating.  Clearly that can't be your problem, but if you have AC it could be the compressor clutch.  Check your fan if it has a clutch, or the bottom of the shroud if it isn't in the retaining clips.
« Reply #4 on: September 01, 2009, 01:24:15 PM »
I think know what your problem is now . . .
Your engine has probably backfired at some point and blown a piece of the muffler loose.
I blew the whole front end loose on mine Saturday and even after temporarily hammering it back together it sounds like shit.  Oh and like there are loose quarters bouncing around.
my71mach1
« Reply #5 on: September 01, 2009, 04:30:53 PM »
Ya know it did backfire when my carb went bad but i had the loose change sound before that its definetly in the exhaust somewere ....
my71mach1
« Reply #6 on: September 01, 2009, 04:34:04 PM »
ok and to note the exhaust is a flowmaster no headers..
my71mach1
« Reply #7 on: September 16, 2009, 06:51:22 PM »
Found its a baffle loose in the pas side muffler will have to replace over winter :)
« Reply #8 on: September 16, 2009, 10:03:38 PM »
glad you found it!
