Author Topic: Power-Steering ?  (Read 3319 times)
Silverfox193201
  • Mustang: 1965 Coupe
  • Daily driver: Ford Mustang 1965
Power-Steering ?
« on: March 05, 2013, 02:12:37 PM »
Had a complete front end Redone, 11-10-18-2012, on my 1965 Mustang 289-v8 A-Code Engine,  which included the power steering control valve and center Link assembly, New p/s Pump and the p/s Slave cylinder also. I have great power assist to the right, and none to the left. It won't return to center by itself from left or right out of a curve.? A local FORD DEALER Mechanic did all the work there. I have taken it back 4 times since the same day I picked it up from them complaining about it. They have kept it a day to three days and can find nothing wrong according to them. All is well per them. Can someone shed some light on this for me??????????????????
Silverfox193201
Topless_Horse
  • Mustang: 66 convertible
Re: Power-Steering ?
« Reply #1 on: March 06, 2013, 09:30:04 AM »
It sounds like there's an issue with your control valve but before you do anything else, can you confirm that you properly bled the system after it was installed?  To bleed the system you need to have the engine running, then turn the steering wheel slowly to the left lock, then to the right, then to the left, then right, ... at least 5 times or until all the air is bled out of the system.  You should also be checking your power steering fluid level during this process to make sure that you don't run it low (that can damage the pump).  Also, if it's an original pump, confirm that you used Type F transmission fluid in the system.  If you didn't, you need to flush whatever is in there out and fill it with the Type F, then bleed the system.
After you've bled the system, if you still have the problem then you should get underneath and confirm that neither of the little hoses that goes to the control valve is kinked or damaged.  If all that checks out OK then you probably have a malfunctioning control valve.
Personally, I would find a different mechanic too.  Mechanics these days do not always understand the old systems and being a Ford dealer is not a default indication of competence.  If you have any local car clubs join and ask them for their recommendations.
