Author Topic: No brake lights  (Read 5826 times)
CrazyLarry
  • Mustang: 1964 1/2
  • Daily driver: 2000 Jeep Wrangler
No brake lights
« on: May 10, 2011, 11:55:06 AM »
Hello,
I've got a '64 1/2 289.  I've got headlights, parking lights, and turn signals, but no brake lights.  Also the dash light for one of the turn signals is out.  Since the parking lights come on, I believe it is safe to assume that its a wiring issue.  My plan is to remove the stoplight switch and clean the wire terminals at the connector.  I gathered this from a manual I'm reading, so I've never done it before...does anyone have any suggestions?  How about getting to and replacing the turn signal light thats out?
Rat Fink
  • Mustang: 2011 mustang GT
  • Daily driver: 2011 mustang
Re: No brake lights
« Reply #1 on: May 11, 2011, 02:12:52 PM »
Jump across the two wires on the brake switch, this will tell you if the switch is bad or not. If your brake lights come on, replace the switch.
CrazyLarry
  • Mustang: 1964 1/2
Re: No brake lights
« Reply #2 on: May 16, 2011, 11:03:49 AM »
Man, I really need a manual dedicated to the 64 1/2.  The Haynes manual I have shows the exact same switch you posted, along with a diagram on where it is located.  So I removed the front seat, wedged myself under the dash and...no switch.  I rooted around thinkin it might be hidden, but how could it be if it was supposed to be connected to the brake pedal?  The answer is that it is under the hood, screwed onto a coupling to the master cylinder.  The only reason I can think that it would be different is because of the generator, since it was the only model to have one.  My manual only gives you diagrams of the most common design for Mustangs b/w 64.5 - 73, which in cases like this is completely different than what I'm looking at.  Any ideas on a definitive 64.5 manual?
ouch1
Re: No brake lights
« Reply #3 on: May 16, 2011, 02:59:49 PM »
Dunno off the top of my head man, but one guess wold be to check on the master cylinder. I have seen the switches located there on older fords.
CrazyLarry
  • Mustang: 1964 1/2
Re: No brake lights
« Reply #4 on: June 27, 2011, 10:47:05 AM »
Yep, that was it.  On top attached to the master cylinder.  I replaced it because it was pretty corroded and the part was cheap.  Unfortunately it did not give me brake lights.  I did a little more research and found out that the brake lights run through the head lights via a circuit breaker.  So I picked up a replacement circuit breaker in the hope of replacing it but I don't know where it is.  Can some help...and if I'm goin about this a$$-backwards, please stop me.
Thanks,
CL
ouch1
Re: No brake lights
« Reply #5 on: June 27, 2011, 02:54:46 PM »
I recommend checking the wiring diagrams on the following webpage and they will point you to the correct location for the circut breaker.
http://www.midlife66.com/wiring/wiring.html
I also recommend checking out the diagram for the 66 exterior lighting. It might help some.
-ouch1
Topless_Horse
  • Mustang: 66 convertible
Re: No brake lights
« Reply #6 on: June 28, 2011, 07:00:37 AM »
Do the brake lights come on if you connect the two wires going to the switch terminals?  If they do then either the switch is bad and you need to replace it, you do not have the right switch and you need to get the right switch or you're not getting pressure from the master cylinder to activate the switch.
To replace the turn indicator you need to remove the instrument cluster enough to get you hand in behind it to pull the socket for that bulb from the back of the cluster, replace the bulb and reinstall the socket in the cluster.  Remember that the speedometer cable may have to be removed from the rear of the speedometer to get enough clearance.  Also put a towel or other pad on top of the steering column so you don't scratch it up.
