Author Topic: Need Help with Rear End Problem on my 70 Mustang  (Read 2689 times)
blk66stang
  • Mustang: 1966 Coupe
« on: November 23, 2008, 04:24:01 PM »
I have problem that I need help with.
I have a 70 Mustang sportsroof that I am trying to bring back to life. I have it running, steering, shifting and stopping. The problem that I am having is in the rear end (somewhere).
I have only driven up and down the driveway. At the same spot when I back up there is a feel and sound that comes from the back end. It almost feels and sounds like something is binding up and then releasing. It is bad enough that I can actually feel it in the drivers seat. I had my two neighbors watch while I backed up and pulled forward. One of them thinks it is in the rear end. The other thinks it is in the rear, passenger side wheel (he thinks that the rear, passenger side wheel actually moved when it happens).
Here is some additional information:
1. Rear end is out of another model of Ford. The tag is "WDZ-8(or B?)1(or I?) 9EB 3L00 8 875A". So it is an 8" posi out of ? Fairlane?
2. The parking brake cables are not connected to anything (they are both hanging down).
3. When I apply the brakes and come to a stop the car rocks back and forth a little.
4. I raised the rear end up and turned the rear tires in both directions. They were hard to turn. And in certain spots (every 3rd full turn or so) they were very very hard to turn. Both tires turned together in the same direction. There was no play in the driver side tire. There however was about 1 1/2" of play in the passenger side tire. What I mean by that is when I turned the tire it turned about 1 1/2" before the axle engaged and the drive shaft turned. And when I turned the driver side tire the axle would turn and the drive shaft would turn immediately but the passenger side tire would not turn until the driver side tire had turned about 1 1/2".
5. The drive shaft and rear U-joint seem to be solid with no movement in /out, up / down or side / side.
6. I took the wheels off. The brake drums don't match. They have the same width and height dimensions but the profile is different. The hole in the passenger side drum that the axle hub sticks thru is also 5/16" bigger in diameter that the hub. So even though the lug holes are correct (correct pattern), the hub hole is not and the drum is loose.
7. I took the brake drums off. The brake components seem to all be there and installed correctly. The brake shoe adjusting device on the passenger side was not competely slid into the indented slot on the brake shoe. I just simply slid it back into position.
8. When I pulled on the end of each axle they did not move in / out or seem loose.
I think that is all I know. If there is something else that would help someone figure out the problem, just let me know.
Thanks.
Re: Need Help with Rear End Problem on my 70 Mustang
« Reply #1 on: November 23, 2008, 04:50:55 PM »
You might  have a wheel bearing that has gone south in the pax side.  Take the axle out and inspect it carefully.  If that isn't it, then unhook the driveshaft at the differential, jack up the rear, and try turning the wheels again.  Barring the bearing being bad, your only other suspicion would be the ring and pinion worn out and binding on each other.
blk66stang
« Reply #2 on: November 23, 2008, 06:11:29 PM »
Thanks. It looks like I have another winter project to add to the list. Thanks again.
blk66stang
« Reply #3 on: November 23, 2008, 06:32:28 PM »
I emailed the gentleman that I purchased the Mustang from and told him about the problem with the rear end. He said that he had new bearings installed by a machine shop.
If the bearings are bad (or maybe installed incorrectly) should I feel something when I turn or pull on the end of the axle when I have the wheel and brake drum off?
blk66stang
« Reply #4 on: November 24, 2008, 01:10:42 PM »
I might add some additional information. I wrote that the brakes looked okay, but the rear passenger side brake is covered with fluid (brake fluid from the cylinder I would guess). Would this be part of the problem?
Also, my driveway is sloped, so when I back up I am applying the brakes. When I pull forward I am accelerating. I do not remember hearing / feeling anything when I pull forward, just when I back up.
Thanks.
« Reply #5 on: November 24, 2008, 06:09:17 PM »
It's possible.  Put a new wheel cylinder in, put on new shoes,  Clean up the drum, then see how it feels.  You are going to have to do that anyway, so add that to your winter projects.  As far as the bearings are concerned, take the wheel and brakes off, then grab the axle end in both hands and shake it back and forth.  It there is any play at all, the bearings are shot.  If they are tight, then it must be something else.  Let us know how it goes.
Don A
« Reply #6 on: December 01, 2008, 05:14:03 AM »
Sounds as if the rear is a locking type.  Lift one wheel and see if you can turn t the other. If it doesn't turn without a lot of effort you have a locking rear.  Locking rears require a special lubricant or possibly simply an additive.
Don A
« Reply #7 on: December 01, 2008, 05:16:19 AM »
Opps--Forgot to add--One wheel on ground---Transmission in neutral
« Reply #8 on: December 01, 2008, 07:01:33 PM »
Yeah, if it is an open rear with the pax side rear wheel off the ground, the right rear wheel will spin and the driver's side won't move.
Last post April 15, 2009, 06:11:49 AM
by treading
Last post January 24, 2009, 05:14:03 PM
Last post December 10, 2011, 02:44:36 PM
by BSC
Last post May 05, 2010, 11:31:23 PM
Last post January 18, 2012, 03:25:46 PM
by jake66
