If your Mustang is already a V8 then it's an easy swap. If you want to keep the fuel injection it will be more complicated to incorporate that. You MAY need to change the bellhousing, depending on how early your car is (early V8 cars had 5 bolt bellhousings, later ones use 6 bolt units).
