Author Topic: Need 4-5 speed trans  (Read 1966 times)
timsweet
  • Mustang: 1970 Coupe
  • Daily driver: 2007 Corvette
« on: October 03, 2011, 09:05:27 PM »
Ok..time is up for the original 3 speed trans in my 1970 mustang.
I want a 4 or 5 speed and I what it to snap write in.
Who's got what I need?
Thanks.
Tim
Re: Need 4-5 speed trans
« Reply #1 on: October 04, 2011, 11:10:02 PM »
keisler engineering  T45 5 speed-use factory bellhousing and clutches-they even custom make you a driveshaft.  We had to clip about a 1/4 by 2" piece of metal out of the transmission tunnel underneath the shifter and modify the motor mounts to get perfect fit and drivetrain alignment.  everything in one package
timsweet
« Reply #2 on: October 05, 2011, 10:42:56 AM »
Jeff - you had to make those modifications to a 1973?
Thanks
« Reply #3 on: October 06, 2011, 09:55:13 AM »
Yes if you want the drive line angle to be right you really do need to modify the motor mounts-it is not a big deal and Keisler sends you technical drawings.  As to the tunnel mod-it is close, but we trimmed that little bit of a tab off of mine just to avoid interference under acceleration.
