First of all, your timing light will only give you a reading from spark plug #1 which is the first plug on the passenger side of the engine next to the radiator.
A misfire could be a myriad of things. Bad plugs, wires or a set of points that aren't adjusted properly. It could also be fuel related such as moisture in the tank. It sounds like you just need a general tune-up.
