Author Topic: Manifold tag  (Read 3224 times)
Jeff1967
  • Mustang: 1967 convertible
Manifold tag
« on: February 16, 2009, 05:43:14 PM »
During my engine compartment detail on my 67' convertible I found a metal 1/2" X 2" tag with:
289  E  67
K  E  -236-A  14
Does anyone know what this is telling me? I promise no knee or hip surgery information replies.
Thanks,
Jeff
Re: Manifold tag
« Reply #1 on: February 16, 2009, 06:03:53 PM »
It just says it is for a 67 289, and the other numbers are date and part numbers.  Looks like November 5.  Nothing special.
Re: Manifold tag
« Reply #2 on: February 16, 2009, 07:51:49 PM »
It breaks down as follows:
289  E  67
289=Displacement; E=Assembly plant; 67=Model Year
K E 236-A 14
K (look again, should be a number, 8); E=May; 236-A Engine Code for a 289 2 barrel (C-code) the 'A' is a special modifier, possibly for air conditioning; 14=change level
Jeff1967
Re: Manifold tag
« Reply #3 on: February 16, 2009, 09:02:33 PM »
Jim,
What does 14= change level, What is change level?
Thanks
Re: Manifold tag
« Reply #4 on: February 16, 2009, 10:28:29 PM »
Change levels are indications of changes made to the engine while in production. As an example, change level 14 installed heavier valve springs. It was done in September 1966 for both Cleveland and Windsor built engines. Back then it made a difference in engine rebuilds. Today not so much as the variety of parts has been reduced so whoever might rebuilds your heads, may or may not use the heavier type valve springs as there may be only one type available.
Over the years, rebuilders tossed all the tags (engine, carburetor, rear axle, etc) as they didn't care what it was, they just did it.
