Author Topic: lock cylinders  (Read 1751 times)
TheJ
lock cylinders
« on: June 09, 2011, 07:51:40 PM »
Is it possible to use a door lock cylinder for the trunk lock in a 73 Mach 1?  This way I only need one key.
Thanks for looking.
Re: lock cylinders
« Reply #1 on: June 09, 2011, 08:49:14 PM »
not a bad idea!  Without having one in hand I would think it is possible to alter a door lock to accept the rod mechanism for the trunk.  The door locks have a piece riveted to the rear that turns to the side to actuate the rods in the door.  The trunk lock has a rod that inserts into it.  It might take using parts from two locks to make your idea work, but I bet a locksmith could whip it up without a problem.
TheJ
Re: lock cylinders
« Reply #2 on: June 09, 2011, 09:17:36 PM »
Yeah, like you said I should probably take it to a locksmith and see if he can do it.  I originally thought I could get the lock re-keyed but it uses a different type of key for the trunk.  I'm gonna look closely at the two lock cylinders for similarities.
Thanks for the info.
